I have a flawless Orion 4004 only used for 1 day then taken outa my car cosmetically and mechanically this amp is flawless looking for 125 plus shipping obo
Featues
* Polished gunmetal heatsink with etched Orion logo
* Mil-Spec double-sided circuit boards
* Massive power supply
* Complementary bipolar output stage transistors
* Selectable 100 Hz high-pass or low-pass crossovers
* Switchable 16 dB INTELLi Bass equalization
* Selectable 2/4-channel input
* Satin finish direct-wire power and ground connections
* Speaker level inputs
* Removable end caps
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 50W x 4
* THD at 4-Ohm RMS Power:
* Bridged RMS Power @ 4 Ohms: 200W x 2
* Speaker Level Inputs: yes
* Preamp Outputs: no
* Built-In Crossovers: HP/LP
* Bass Boost: 0 or 16 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: 80 dB
* Dimensions: 15.9 L x 10.5 W x 2.3 H
Featues
