Sold FS: Kinetik HC2000 & Mtx Te1004
Apollo220
i have a used kinetik hc2000 battery , and barely used still NEw condition Mtx te1004. kinetik 225 shipped ... Amp 320 shipped obo on both ..don't low ball any offers tho...amp does come with a bass knob and mounting hardware
Kinetik HC2000 Power Cell 225 shipped (sold)
Unstoppable output and high reserve capacity to back it up! More powerful than any other brand of power cell. Fits Chevy or Dodge trucks and many other larger vehicles.
Specifications
Weight: 61 lbs.
Ah: 102
Amps: 2250
Dimensions: 12" x 6.5" x 8.2"
Suggested Retail: $399.00
All Kinetik HC Power Cells Feature:
AGM Technology
Sealed Non-Spillable Design
Mount In Any Position
Ultra Low ESR
More Plates For Stronger Energy Density
Higher Voltage Under Load
Tightly Packed Cells
Superior Heat & Vibration Resistance
TE1004 Specifications $320 shipped Still Brand New
# OF CHANNELS 4
MINIMUM SINGLE CHANNEL IMPEDANCE 2
CLASS A/B
AMP OPTIMIZED FOR FULL
POWER SUPPLY Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + NOISE (1 Watt) ≤.25%
FREQUENCY RESPONSE (-3dB) 20Hz-20KHz
SIGNAL-TO-NOISE RATIO (1 Watt) 75 dB
OVERLOAD PROTECTION x
THERMAL PROTECTION x
14.4VDC POWER 4 Ω 125 X 4
2 Ω 225 X 4
4 Ω Bridged 450 X 2
2 Ω Bridged 950 X 1
Peak Power 1900
BI-LEVEL INPUT (RCA Connection) Low Level x
Hi Level w/ Smart Engage (Pat. No: US06556683) x
INPUT SWITCH Input Sense 100mV-1V/1V-10V x
Input Select 2/4 Channel x
GAIN CONTROL Stereo - 100mV-10V x
Mono - 100mV-10V x
CROSSOVER HI, 12dB / LOW, 24dB MONO @ 40Hz-350Hz, DEFEAT x
RCA OUTPUT SUM, Front/Rear x
EQUALIZATION THUNDER EQ: BOOST 0-18dB,
FREQ. 40Hz x
ARC: CUT 0-15dB, FREQ. 200Hz x
OTHER FEATURES Remote Subwoofer Level Control Parallelable x
Dual Mono Output x
Prizm EFX With Demo Mode x
POWER CONNECTION 4 Gauge Direct Input With 8 Gauge Direct Cap Input x
DIMENSIONS Height 9-5/8"
Width 20-11/16"
Depth 2-1/2"
Apollo220
Apollo220
Columbus, GA
Apollo220
