Sold FS:Kinetic 1400 & 1800
my alti said it on the alt.. look for a small metal shiny plate.. might be a sticker or engraved... its all dependent.. if you can find a package deal.. do it.. these two batts an amp and sub will do ya.. the 1400 in front the 1800 in back.. depending on power should hold ya.
well to get rid of my dimming i did big 3 and got both of these 1400 fit up front and the 1800 in the rear. i have a 94 civic so i would recommend both on stock alt. worst you would have to do is check charge once a week and charge if neccessary. capacitors are a waste of money never go that route unless you want it just for the cool led voltage display //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes: .
* Kinetik HC 1800 - 1900 amps, High Current Car Audio Power Cell HC1800
* AGM Technology
* Sealed Non-Spillable Design
* Mount In Any Position
* Ultra Low ESR
* More Plates For Stronger Energy Density
* Higher Voltage Under Load
* Tightly Packed Cells
* Superior Heat & Vibration Resistance
* Kinetik HC1800 Power Cell
* Full size powerhouse.
* Fits vehicles with larger battery boxes.
* Capable of powering nearly any system without compromise.
* Weight: 54 lbs.
* Ah: 81
* Amps: 1900
* Dimensions: 10" x 6.5" x 8.2"
bought for competition season. Selling because I need subs. bought the 1800 from member JJDAVID123 on here. The other a local kid who never got to using the 1400 for a battery relocation.
SPL KID
SPL KID
Raleigh, NC
SPL KID
