Excellent shape, comes with NEW endcaps, and the amp cover is painted glossy black, pictures will be up sometime this weekend when I can make it over to my parents.
http://www.cardomain.com/item/KIC04SX9004
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 16kHz variable high-pass frequency adjustable in 1/12th octave steps
30Hz – 20kHz variable low-pass frequency adjustable in 1/12th octave steps
6 – 36dB / octave variable crossover slopes
Digital KickEQ fully parametric equalizer
20Hz – 20kHz variable frequency adjustable in 1/12th octave steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable left / right independent phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display
RMS Power @ 4 Ohms: 112.5W x 4
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 450W x 2
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: 3 x 40 amps
350 shipped
Memory presets
Preamp Outputs: yes
350 shipped
