Sold FS: Kicker SX600.2 amplifier $295 shipped
FoxPro5
Causal wanderer
I installed this BNIB about two weeks ago. I upgraded to the 900.2, so this one has to go. It will look and perform just like you got it from the factory. The factory registration card is still in the box along with everthing else: manual, remote bass controler and wire, birth sheet, everything!!
At 13.8v, .02% THD
138x2 @ 4 ohms
275x2 @ 2 ohms
550x1 @ 4 ohms bridged
Birth sheet reads 645 watts at 14.4v
40x2 fuse rating
Bandpassable
Fan cooled
Removable end caps
DSP fuctions up the wazoo //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
$295 shipped in the US with PayPal.
If I've done business with you before and are interested, PM for price! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
lol thanks Fox like i said i know very little im running the sub stated above with a 350 watt infinity amp i think the amp is a mono.. i am thinking on adding another sub and i guess another amp... and i was just wondering if this amp would work well thanks anyway.
No problem. Like I said, this would be a great sub amp...it has the balls, would run nice and cool, and has a ton of great features. But you need to show it a final impedance of 4 ohms. Therefore, you would need two 4 ohm DVC subs if you were going to run a pair or one 4 ohm SVC sub. Also remember that each sub would get half the total power...so ~300 watts each from this amp.
hang on so i can get 300 watts to both 4ohm subs ? cause 300s the maxx on them that would work badass wouldnt it?
Yes, the amp puts out 600 watts RMS at 4 ohms bridged. You NEED two DUAL 4 ohm subs....NOT two 4 ohm subs though. If you had two 4 ohm subs, your wiring options are 2 ohms or 8 ohms....neither of which is optimal for THIS amp.
If you already have one 4 ohm sub and want another one, then you need something like the Kicker SX650.1 (mono amp) which puts out 650 watts at 2 ohms. In this case each sub would get 325 watts. Get it??? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The everyday price for this amp on ebay is ~$350 BNIB //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif You won't find a more capable 2 channel at this price anywhere!!
I guarantee this bad boy NOT DOA!! Check my feedback //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
FoxPro5
