Sold FS: Kicker SX500.2 w/ DSP and Kicker SXRC amp controller
probmxstyle
The Well Dressed OG
As the title says, I am selling a 4 month old Kicker SX500.2 2 ch amp. The amp looks brand new except for a very small scuff on one of the end caps. This is a awesome amp becuase you really can contol everything on this amp. Included with the amp will be the owners manual. I am also selling a 3 month old Kicker SXRC amp contoller. You connect this to the amp and remotely mount it anywhere in the car using a ethernet cable. It can also be mounted in a single din area. It comes with the single din mounting hardware, all the hardware and owners manual. I am looking to get 300 for the amp and 150 for the controller plus shipping. Here are the specs of the amp:
Every once in a while something comes along so radical, so out there, that everything that came before it just seems "regular." The new Kicker SX series amplifiers with 32-bit digital signal processing blast car stereo to a whole new level of power and control. Forget about knobs and switches, and forget about limits. The Kicker SX gives you total control and tons of legendary Kicker power.
Built-In 32-Bit Digital Signal Processor (DSP)
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 16kHz variable high-pass frequency adjustable in 1/12th octave steps
30Hz – 20kHz variable low-pass frequency adjustable in 1/12th octave steps
6 – 36dB / octave variable crossover slopes
Digital KickEQ fully parametric equalizer
20Hz – 20kHz variable frequency adjustable in 1/12th octave steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable left / right independent phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display
The flexibility and precision of DSP is just the beginning. The SX series is all about pure, clean, audiophile power, with handpicked tight-tolerance components and a no-holds-barred design philosophy.
Features
Audiophile components throughout
Double-sided glass epoxy circuit boards with large copper traces
Oversized Litz wound toroidal transformers for improved efficiency
Large TO-218 bipolar output devices for higher current capacity and reduced resistance
Triple Darlington output device configuration for lower distortion and excellent sound quality
Custom-wrapped HFQ electrolytic capacitors for maximum bass impact
Precision tolerance metal film resistors and poly film capacitors in the audio signal path
Isolated dual power supplies
Fan cooled
Remote level control
Custom-tooled oversized power and speaker output terminals
PreAmp Signal Transfer (PAST) output RCA lack
Soft muting circuit controlled by the DSP
Soft start turn-on circuit for deduced startup load
Removable cast aluminum EndKaps
2-Channel Amp SpecificationsAmplifier Type: 2-channel
RMS Power @ 4 Ohms: 125W x 2
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 500W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: 2 x 30 amps
Here is the specs of the SXRC:
Digital remote bass level with 30 dB of attenuation
Four global memories for instant system recall
Remote control of all SickBay and Diagnostic functions
10 user-assignable groups controlling multiple amplifiers
Blue vacuum fluorescent display (VFD) matches SX series amplifiers
Variable display brightness
Blue backlit ISIS keys
Provides current date and time
Default voltage and temperature of selected amplifier scrolls across screen
User-assignable lock code
Metal mounting bracket and in-dash trim bezel included
I may be interested. What are the dimensions and is it a 4 ga input?
Dimensions: 15.5" long w/o endcaps and 19.25" w/ endcaps. It is also 9" wide
And yes it does have 4 ga inputs with room to spair. So you could more then likely fit larger wire in it. Also has 8 ga speaker wire outputs.
probmxstyle
The Well Dressed OG
probmxstyle
MD
probmxstyle
