Sold FS: Kicker KX650.1 - $175 OBO
sundownz
Pro Seller
Supporting Vendor
FS: Kicker KX650.4 - $175 OBO
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
# 4-channel car amplifier
# 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
# 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
# cooling fan
# 2-, 3-, or 4-channel output
# CEA-2006 compliant
# Tri-way capable (Tri-Way crossover required)
# speaker- and preamp-level inputs
# variable front and rear high-/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
# variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
# three-way protection circuitry
# requires 4-gauge power and ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
# 22-1/2"W x 2-9/16"H x 9-15/16"D
Title fail //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif say's 650.1! Interesting, Main post title say's 650.4 But the posts after say 650.1
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
