Sold FS Kicker KX350.4 and KX200.2 combo $150 plus shipping
Kryptonitewhite
Specs? I may be able to use these.
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
variable high-pass/low-pass filters (50-200 Hz, 12 dB/octave)
variable bass boost (0-18 dB at 40 Hz) with wired remote level control
speaker- and preamp-level inputs
CEA-2006 compliant
Tri-way capable (Tri-Way crossover required)
fuse rating: 20A x 2
8-gauge power and ground lea
Product MPN
MPN: KX200.2
Key Features
Amplifier Type: Dual Channel
Bridgable: Bridgable
RMS Power at 4 Ohms: 50 W x 2
RMS Power at 2 Ohms: 100 W x 2
3 Way Ready : Yes
Number Of Channels: 2
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 95 dB
THD at Rated RMS Power: 0.09 %
Crossover / Equalizer
Bass Boost: With Bass Boost
Bass Boost Frequency: 40 Hz
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 10.13 in.
Depth: 16 in.
Height: 2.5 in.
Miscellaneous
UPC: 013034009901
Product ID: 20295466
More Information
Details: 100W x 2 Car Amplifier. Stereo Or Bridged Mono Output. Tri-Way Capable.
KX350.4 and KX200.2 shipped $130
add $10 shipping and $20 for a KX1200.1 that needs repair. The KX1200.1 works fine until you crank it up, then it will shut off for a second and come back on. I have an RA# from Kicker to have it sent in. I would ship it to you with the other two amps then you send to Kicker.
KX350.4 and KX200.2 and KX1200.1 shipped $160
the BRZ3000 is out and kicking...
they did away with the comp grade stuff cuz the market is not big enough for it..
just here...
ANT asked me back on ROE and offered free vendor space and ads ect but I have not done anything with it...
CSF has done the same but me n the CDT vendor do not get along so I stay away from there...
The BRZ3000 looks wicked! Website said discontinued lol
Come back and say hey on ROE you cant be stuck to just one forum //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Kryptonitewhite
Kryptonitewhite
soo foo sd
Kryptonitewhite
