Sold FS: Kicker amps and EQ's
MSSOKC
Need to get rid of these. Awesome amps.
SX650.4 $275
SX850.4 $350
KQ30 $125
AMP SPECS:
Every once in a while something comes along so radical, so out there, that everything that came before it just seems "regular." The new Kicker SX series amplifiers with 32-bit digital signal processing blast car stereo to a whole new level of power and control. Forget about knobs and switches, and forget about limits. The Kicker SX gives you total control and tons of legendary Kicker power.
Built-In 32-Bit Digital Signal Processor (DSP)
24-bit audio resolution
44.1kHz sampling frequency
0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
Kompressor adjustable expansion / compression system
Contour Mode fattens bass output at low to moderate listening levels
Attack Mode enhances the sharp, quick attack in bass and midbass
Redline Mode controls dynamic peaks for a more even output
Digital high- and low-pass crossovers
10Hz – 16kHz variable high-pass frequency adjustable in 1/12th octave steps
30Hz – 20kHz variable low-pass frequency adjustable in 1/12th octave steps
6 – 36dB / octave variable crossover slopes
Digital KickEQ fully parametric equalizer
20Hz – 20kHz variable frequency adjustable in 1/12th octave steps
0.5 – 10 variable bandwidth (Q) in 0.5 increments
Boost or cut 0 – 18dB in 1dB steps
Selectable left / right independent phase
UltraMatch gain control circuit
5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
1, 2, 4, 8, or 16-volt input range selection
12dB adjustment in 0.5dB steps for each input range
Memory presets
4 presets for installers or tweak-a-holics
Each preset is pre-loaded with common settings for easy setup
Customize each preset for quick access
Sick Bay diagnostics
Real-time amplifier diagnostics and troubleshooting
Keeps a running history of past trouble faults
Check current voltage and temperatures
Recall minimum and maximum voltages
Recall minimum and maximum temperatures
ISIS Vacuum Fluorescent Display
The flexibility and precision of DSP is just the beginning. The SX series is all about pure, clean, audiophile power, with handpicked tight-tolerance components and a no-holds-barred design philosophy.
Features:
Audiophile components throughout
Double-sided glass epoxy circuit boards with large copper traces
Oversized Litz wound toroidal transformers for improved efficiency
Large TO-218 bipolar output devices for higher current capacity and reduced resistance
Triple Darlington output device configuration for lower distortion and excellent sound quality
Custom-wrapped HFQ electrolytic capacitors for maximum bass impact
Precision tolerance metal film resistors and poly film capacitors in the audio signal path
Isolated dual power supplies
Fan cooled
Remote level control
Custom-tooled oversized power and speaker output terminals
PreAmp Signal Transfer (PAST) output RCA lack
Soft muting circuit controlled by the DSP
Soft start turn-on circuit for deduced startup load
EQ Specs:
For the ultimate in sound shaping, only a 1/3 octave equalizer will do. Kicker's KQ30 gives you a full 30 bands of equalization plus a built-in 9-volt line driver. Individual rotary knobs control up to 12 dB of boost or cut for each equalizer band. Separate input and output level controls with fast-acting clip indicators allow for easy system matching and noise-free signal to your amplifiers. Features unbalanced RCA inputs and outputs, EQ defeat switch, and stereo/mono operation.
Features
30 Band Stereo Equalizer with 1/3 Octave Band Spacing
Fast-Acting Signal Clip Indicators
Separate Input and Output Level Controls
EQ Defeat Switch
Stereo / Mono Operation Switch
Specifications
Equalizer Bands: 30
Maximum Boost / Cut: 12 dB
Input Sensitivity: 500mV – 9V
Maximum Output Level: 9V RMS
Signal-To-Noise Ratio: >95 dB
you covered just about every spec except the most important ones....
wattage ratings, and dimensions. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
(of course I looked them up, but you should post them)
I was going to use them for a 5.1 set up in my car. I have a pair running an active 3 way set and love them. Very cool amps. Here's specs:
SX650.4 birthsheets show right at 100x4 @ 4 ohm
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 87.5W x 4
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 350W x 2
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: 2 x 40 amps
SX850.4 birthsheets show 130x4 @ 4 ohms
RMS Power @ 4 Ohms: 112.5W x 4
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 450W x 2
Preamp Outputs: Yes
Fuse Rating: 3 x 40 amps
MSSOKC
MSSOKC
Moore, Ok now San Antonio, Tx
MSSOKC
