Sold FS: Kicker 150.2 [] 2 channel 203watts [] $55shipped
Woodmister
Radford!
Kicker Kx150.2 $55shipped or will help in the trade for your D class amp (~300-400watts)
Practically brand new, works perfect, birth sheet said it does 203watts @ 4ohms @ 14.4volts. So i would assume it does around 100w x 2, prefect for a small sub system or some components...
# 2-Channel KX-Series Power Amplifier
# Low Impedance Operation
# SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
# MOSFET Power Supply
# KickBass: 0-18 dB @ 45 Hz
# Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
# High & Low level inputs
# PAST (PRE Amp Signal Transfer) Output RCA jacks
# Custom tooled gold plated connectors
# SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
# Cast aluminum EndKaps
# RMS Power Ratings:
* 14.4V:
o 60 watts x 2 chan. @ 4 ohms
o 75 watts x 2 chan. @ 2 ohms
o 150 watts x 1 chan. @ 4 ohms
* 12.5V:
o 30 watts x 2 chan. @ 4 ohms
o 60 watts x 2 chan. @ 2 ohms
o 115 watts x 1 chan. @ 4 ohms
# Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
# Dimensions: 12-3/4" L x 10-1/8" W x 2.5" H
Woodmister
Radford!
Woodmister
NorthVA
davidfre21
