I have a like new pair of L7s they are the 08 model i have hardly used them had them for two months. Still stiff and smell new wanting 200+shipping
specs
Size (IN.,CM) 8, 20.32
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450
Sensitivity (dB 1w/1m) 83.6
Frequency Response (Hz) 28-100
Mounting Depth (IN.,CM) 4-3/4, 12.1
Mounting Cutout, Square (IN.,CM) 7-1/4, 18.4
Min Rec Sealed Box Volume (CU. FT., Liters) .33, 9.4
Max Rec Sealed Box Volume (CU. FT., Liters) .75, 21.2
Min Rec Vented Box Volume (CU. Ft., Liters)** .66, 18.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 1.0, 28.3
pics
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0012.jpg
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0010.jpg
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0011.jpg
Audiobahn abc 500 5 1/4" 45+shipping obo
specs
5 1/4" 2-Way Component Speaker
Power Handling:
Peak: 320 watts per set / 160 watts each side
RMS: 160 watts per set / 80 watts each side
Carbon Honeycomb Cone
Butyl Rubber Surround
2-Layer High-Temp ASV Voice Coil
25mm Silk Dome Tweeter
Strontium Mid-Woofer Magnet
Neodymium Tweeter Magnet
Chrome Plated Cast Aluminum Basket
Component Matched 18dB per Octave Crossover Network
Complete with Mounting Hardware
Surface or Flush Mount
Frequency Response: 35Hz - 25kHz
Sensitivity: 90dB
4 Ohm Impedance
18 Oz. Magnet
pics
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0009.jpg
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0008.jpg
Kenwood KAC7201 70+shippig
specs
AmpGuts - Kenwood KAC-7201Kenwood KAC-7201
← home
2 x 150W @ 4 ohms (20Hz ∼ 20kHz, 0.08% THD)
2 x 230W @ 2 ohms (1kHz, 0.8% THD)
1 x 460W @ 4 ohms bridged (1kHz, 0.8% THD)
Freq. Response: 5Hz ∼ 50kHz
S/N Ratio: 100dB
Current Consumption: 43A (4 ohm, 10% THD)
Fuse: 2 x 30A
Dimensions: 12" x 11.25" x 2.25" (30.5cm x 28.5cm x 5.7cm)
pics
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0007.jpg
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0006.jpg
http://i809.photobucket.com/albums/zz19/kraudio/IMG_0005.jpg
Also i have two other amps i have a jensen xa2150 going for 35+shipping obo
specs
Tri-way capable (Tri-Way crossover required)
75 watts x 2 at 4 ohms
100 watts x 2 at 2 ohms
200 watts in bridged mode
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
speaker-level inputs
high- and low-pass crossovers, variable from 40-240 Hz, 12 dB/octave
6 dB bass boost at 45 Hz
preamp outputs
MOSFET power supplies
gold-plated screw terminals and RCA inputs and outputs
speaker short, thermal overload protection
9-5/16"W x 2-1/2"H x 11-1/8"D
pics pm for pics
then i also have a crunch se200v same as jensen 35+shipping obo
these are all the specs i could find on this amp
100W x 2 channels
- Full Mosfet design circuitry.
- 4 AWG gold plated power & ground terminals.
- Fully adjustable hi-lo crossover.
- 0 - 12 dB variable bass boost.
- Tru-Power VU metering.
- LED triple-protect diagnostics.
- 1 Ohm stable. (less)
specs
pics
specs
Power Handling:
Sensitivity: 90dB
4 Ohm Impedance
18 Oz. Magnet
pics
specs
← home
S/N Ratio: 100dB
Fuse: 2 x 30A
pics
specs
preamp outputs
pics pm for pics
100W x 2 channels
