Sold FS: KENWOOD Amp $100
szym0n
I got this amp just lying around the house. I don't use it at all, i bought it when I wanted to get a nice audio system, but now im saving for an rx8.
$100, Only accept Money order. Shipping will be on me.
if intrested call 708-369-0869
http://www.crutchfield.com/S-jAS3oQw...fo&i=113KAC859
Ease of installation and killer performance are only two of the many reasons you should check out Kenwood's KAC-859 5-channel amplifier. This rugged multi-channel masterpiece has all the features found in its 4-channel brothers along with a hefty 120-watt subwoofer channel. Built-in high-pass crossovers (selectable off/80/150 Hz, 12 dB per octave) on the front and rear channels and a low-pass crossover (variable from 50-200 Hz, 18 dB per octave) on the subwoofer channel direct the different frequency ranges to their proper destinations.
Dual power supplies ensure that the 4-channel section is not affected by heavy demands on the subwoofer channel. Read more
Details:
* 3-, 4-, or 5-channel output
* 40 watts RMS x 4 + 120W x 1
* 60 watts x 4 + 150 watts x 1 at 2 ohms
* requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
* speaker-level inputs
* anti-thump circuit for quiet turn-on
* speaker short, thermal overload, and DC protection
* extra-large noise filters
* three sets of gold-plated preamp inputs
* signal-to-noise ratio 100 dB
* independent power supply for subwoofer leaves 4-channel power unaffected by demands of the subwoofer
* 50-200 Hz continuously variable low-pass crossover, 18 dB/octave (subwoofer channel)
* selectable (80 Hz, 150 Hz) high-pass crossover, 12 dB per octave (A/B channels)
* 15-1/8"W x 2-3/8"H x 12-5/8"D
szym0n
szym0n
Chicago, IL
szym0n
