SOLD FS: JVC KW-AVX800 Double Din 7 inch Touchscreen
Colin+M
NEW PRICE $450 plus shipping
Ok, so the active bug has taken over my life once AGAIN:D
This is one badass Double Din folks.
7 inch Touchscreen
5 volt preouts (front, rear, sub, center) Thats right, 5.1 capabilities //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Time Alignment
Speaker Size selection
Speaker Level adjustment
Sub level control
Sub phase control
7 band Graphic EQ
All you need to do is ground the parking brake wire and you've got video on the go, no adapters, boxes needed.
Built in DTS, Dolby Digital 5.1 decoder
Dvd-Audio
Dvd MP3, wav, wma etc
Divx, Divx Ultra
Usb Cable for Mp3 players, Portable HDD
Ipod capable
SD card slot
Aux A/V in for Nav/rearview cam
Bluetooth capable
etc, etc, etc
Pretty much does it all except 3 way active, otherwise it wouldn't be going anywhere.
SQ is comparable to my Pio 880, Alpine 7998. JVC EXAD's are no slouch folks.
The deck was purchased from Circuit City in mid-June and is in excellent condition.
I just wish i would have changed my mind 2 months ago so I could have gotten a full refund //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
My indecisiveness is your gain.
Asking $500 plus actual shipping
Only trades I'll consider is the W200/205 or other fancy active capable h/u's:)
Link for more info
http://www.crutchfield.com/S-jBFVk6XYJAz/cgi-bin/ProdView.asp?g=168550&I=105AVX800
Full Feature list
# Power Output:200W Max. (MOSFET 50W X 4), 20W X 4 RMS
# 7" Wide Touch-Screen Monitor
# Rear USB Port for Video and Audio playback from Flash Memory Drives, Digital AUdio Players and Portable HDD Devices up to 250 GB Capacity
# Ready for Bluetooth® Wireless Technology
# Built-In SD Card Slot
# GIGA MP3 Multi
# 7-Band iEQ/High Pass Filter
# Ready for iPod* In Conjunction with KS-PD100
# SAT Radio Ready*
# MP3/WMA/WAV/CD/CD-R/CD-RW Compatible with ID3/WMA Tag
# DivX Ultra® Certified
# JPEG Display
# DVD-R/-RW,+R/+RW/Multi-Border Compatible
# Built-In 5.1 Channel Decoding
# Front/Rear/Sub/Center/Video Outputs
# AV Input Terminals
# Shock Proof Memory
# WallPaper Setting
# Amp Defeat
# Motorized Faceplate
# Steering Wheel Remote Ready*
# HS-IV Tuner
# Telephone Muting
No thanks on the trades guys, I have a particular niche i need to fill. Really need an Alpine W200/205.
But I will do $500 shipped.
Google do it translate what ever i do
368
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Colin+M
Colin+M
small town, AL
Arisotezza18
