Sold FS: JVC head unit, and alpine speakers
skirch56
First up is a JVC head unit. I am selling this for a friend. I know it works but thats about all I know about it. The model number is KD-S30, its rated a 200w, and has a detachable face plate. The face looks to be in good condition, but the outer trim is missing. It says CD-RW on the face so I am guessing it will accept MP3 disks.
Looking for 50 shipped.
Second is a pair of Alpine type S 5.25 inch 2 way speakers. No box, connectors, manual, or factory grills, just the speakers. I put these in a jeep wrangler for about a month, until I wrecked it. They were just powered off of the head unit, so they weren't abused. I thought they sounded great.
Looking for 45 shipped.
TTT,
Here are some specs, manual says it plays CD and CD-RW.
CD PLAYER SECTION
Type: Compact disc player
Signal Detection System: Non-contact optical
pickup (semiconductor laser)
Number of channels: 2 channels (stereo)
Frequency Response: 5 Hz to 20 000 Hz
Dynamic Range: 96 dB
Signal-to-Noise Ratio: 98 dB
Wow and Flutter: Less than measurable limit
GENERAL
Power Requirement
Operating Voltage:
DC 14.4 V (11 V to 16 V allowance)
Allowable Operating Temperature:
0°C to +40°C (32°F to 104°F)
Grounding System: Negative ground
Dimensions (W H D):
Installation Size (approx.):
182 mm 52 mm 150 mm
(7-3/16" 2-1/16" 5-15/16")
Panel Size (approx.):
188 mm 58 mm 12 mm
(7-7/16" 2-5/16" 1/2")
Mass (approx.):
1.4 kg (3.1 lbs) (excluding accessories)
Design and specifications are subject to change
without notice.
If a kit is necessary for your car, consult your
telephone directory for the nearest car audio
speciality shop.
AUDIO AMPLIFIER SECTION
Maximum Power Output:
Front: 50 W per channel
Rear: 50 W per channel
Continuous Power Output (RMS):
Front: 19 W per channel into 4 ohm, 40 Hz to
20 000 Hz at no more than 0.8%
total harmonic distortion.
Rear: 19 W per channel into 4 ohm, 40 Hz to
Load Impedance: 4 ohm (4 to 8 allowance)
Tone Control Range
Bass: ±10 dB at 100 Hz
Treble: ±10 dB at 10 kHz
Frequency Response: 40 Hz to 20 000 Hz
Signal-to-Noise Ratio: 70 dB
Line-Out Level/Impedance:
2.5 V/20 load (full scale)
Output Impedance: 1
TUNER SECTION
Frequency Range
FM: 87.5 MHz to 107.9 MHz
AM: 530 kHz to 1 710 kHz
[FM Tuner]
Usable Sensitivity: 11.3 dBf
50 dB Quieting Sensitivity:
16.3 dBf
Alternate Channel Selectivity (400 kHz):
65 dB
Frequency Response: 40 Hz to 15 000 Hz
Stereo Separation: 35 dB
Capture Ratio: 1.5 dB
[AM Tuner]
Sensitivity: 20
Selectivity: 35 dB
skirch56
skirch56
Shullsburg, WI
skirch56
