Looking to sell my mint condition JL 1000/1. I purchased this amp 8 months ago from a local authorized dealer. It was only used for 2 months. Comes with original box,manual, also have the optional RBC-1. As far as the price the best offer takes it. Will consider partial trades. Pics available
Email: SuperStallion302@aol.com
Aim: SuperStallion302
Specifications:
Rated Power:
1000 W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
S/N Ratio*:
>95dB below rated power
Frequency Response:
5 Hz-500 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
19.7"L x 9.25"W x 2.36"H
(500 mm x 235 mm x 60 mm)
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (40-200 Hz),
selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ:
parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter:
fully-variable 24dB/octave from 15-60 Hz
Output Polarity Reversal:
switch permits instant output polarity reversal
Dual mono speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept 4ga. wire
Specifications:
Rated Power:
(11V-14.5V)
THD at Rated Power:
S/N Ratio*:
Frequency Response:
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
to 800mV-8V RMS
Dimensions:
Features:
(1 pair of inputs)
On-board Crossover:
Preamp Output:
Bass EQ:
Infrasonic Filter:
accept 4ga. wire
