Sold FS: Image Dynamics Q700.2
Jh8909
1. Product: Image Dynamics Q700.2 2-channel amplifier
2. Specs: Class A/B Two-Channel amplifier
Audiophile Grade NE5532 Opamps
Mosfet power supply
High current bi-polar output design
Soft start / mute circuit
Remote bass level control
input: 2 channel RCA style differential balanced mode
Channels 1&2 Crossover: Fully-Variable 50~5000 Hz (12 db per octave ) LP,F,HP
Sub Sonic Filter: Fully-Variable 10~100Hz ( 12 db per octive )
Channels 1&2 Bass Eq: Fixed at 40Hz with 12db of boost
input Sensitivity: 150mV~5.0V RMS
input Impedence: 20K ohms
rated power ( All channels ): 175 watts @ 4 ohms ( 14.4 VDC )
rated power ( All channels ): 325 watt @ 2 ohms ( 14.4 VDC )
Channels Summed ( Mono ): 650 watt@ 4 ohm ( 14.4 VDC )
Frequency Response ( All channels ): 10Hz~30KHz +/- .5db
THD + Noise ( All channels ): S/N Ratio ( All channels ): >100db
Damping factor @ 50hrz: >100@2 ohms
All speaker outputs connections: Accept up to 8 AWG wire
power input and ground connections: Accept up to 4 AWG wire
Dimensions ( L x W x D ) 18.3 in. x 8.625 in. x 2.0625 in.
465.13 mm x 219 mm x 52.3 mm
3. Description/Condition: mint. tested to make sure it works.
4. Price: : $200 Shipped.
MAN! $200 and its still here?????? Like i said, if i werent diggin the 5 channel amps i would LOVE this thing. Go ahead and grab the ID i5800 and sell it for 200 for me please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
just buy it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Jh8909
Jh8909
Pine Hill, NJ
dennit469
