Sold FS: ID/DLS/Focal
galacticmonkey
Wants a button like that.
2 sets of Focal Polyglass 165VR. One set I took one speaker and hooked it up to hear it. Besides that its absolutely flawless. Other is BNIB, but took it out to check them out. Pretty sure they are BNIB since I bought them from someone online, but even if they were used there is no sign of any mounting scratches or anything. Pretty sure they are BNIB. Both pairs are flawless. Looking for $300 each pair.
* Product type : High sensitivity 2-way kit
* Woofer : Polyglass 165mm (6-1/2")
* Tweeter : TNB aluminium-magnesium inverted dome tweeter
* Voice coil : 32mm (1-1/4")
* Magnet : 90mm (3-9/16")
* Frequency response (+/-3dB) : 80Hz - 28kHz
* Sensitivity (2.83V/1m) : 94.5dB
* Nom. power : 75W
* Max. power : 150W
* Top-mount depth: 2.95"
* Speaker Grilles Included
Also up for sale is a DLS Ultimate A5. Couple very small hairline scratches I THINK. Gotta dust it off and check it out. Might not have any scratches once its cleaned up, just saying it might because its better to say it does and turns out it doesnt. Ill double check tomorrow. Looking for $400.
DLS Ultimate A5
# Ultimate Series "The Big Three" 3-Channel Class AB Car Amplifier
# RMS Power Rating:
4 ohms: 85 watts x 2 chan. + 300 watts x 1 sub chan.
2 ohms: 100 watts x 2 chan. + 500 watts x 1 sub chan.
# LED power and protection indicators
# Bridgeable operation
# Automatic remote turn on/off on high level input without connecting any remote wire
# Short circuit, DC offset, and thermal protection circuitry
# Built-in fan with output for external control
# Gold-plated RCA level inputs
# Gold-plated screw terminals
# High-Pass Crossover Frequency 1 + 2 channels: 50-150 Hz, 6 dB/octave
# Low-Pass Crossover Frequency 40-90 Hz, 18 dB/octave
# Frequency response: 10-50000 Hz
# Dimensions: 16.15"L x 9.45"W x 2.87"H
Last but not least are 2 Image Dynamics IDQ 10 V3s Dual 2. Great condition. One one MIGHT make a small noise at low volume, but it might have just been an air leak on the box. I gotta find out. Im pretty sure its good to go though. Ill throw in a sealed box I built for them for an extra $15 if you want it. Looking for $180 each for $350 for the pair.
* Impedance: Dual 2 ohms* Power Range:50 - 500 Watts RMS
* Mounting Depth: 5.75"
* Mounting Diameter: 9.60"
* Sealed Enclosure Range: .55cu.ft. - 1.1cu.ft
* Ported Enclosure Range: 1.0cu.ft. - 1.5cu.ft.
* Re- DC Reistance: 1.025/ 4.1 Ohms
* Fs- Resonant Frequency: 25.528 Hz
* Qes- Electrical "Q": .470
* Qms- Mechanical "Q": 2.100
* Qts- Total "Q": .384
* Vas- Equivalent volume: 2.5cuft (71 liters)
* Xmax- One way linear: 19.0mm
* Sd- Cone Area: 399.1 cm2
* Splo- Sensitivity: 85dB
* Power: 50-500
* XMax: 17.0mm
* Sealed ft3: 0.70
* Ported ft3: 1.00
All prices are negotiable. Buyer pays shipping and Paypal fees.
galacticmonkey
galacticmonkey
Tampa, FL
galacticmonkey
