Sold Fs: Ia 20.1 + Aq 1200d
j225
First the IA 20.1
Here I have a perfectly working Incriminator Audio 20.1 mono amplifier. The amp is 100% working like it should and puts out tons of power. It only has a couple cosmetic blemishes. Asking $425 shipped including paypal fees.
Power Ratings 1800 watts x 1 at 1 ohm
900 watts x 1 at 2 ohms
450 watts x 1 at 4 ohms
Strapable Pair 3600 watts x 1 at 2 ohms
Protection Circuit 3 Way (Overheat, Overload, Short Circuit)
Frequency Response 10Hz~350Hz
Signal/Noise Ratio 105dB
T.H.D. @ 4 Ohm
Efficeincy @ 4 Ohm 87%
Low Pass Filter 45Hz~300Hz
Subsonic Filter 20Hz~50Hz
Bass Boost Slope 0~18dB
Size 10.25" Wide x 2.25" Height x 21.75" Long
Next the Audioque 1200D SOLD
I had this amp hooked up for about 1 week then I unhooked it and put it back in the box. The amp is 100% working condition and is in perfect mint condition like new. Puts out lots of power as well and its pretty small. Great little amp. Asking SOLD
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @ 1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
j225
j225
Norcross, GA
j225
