1. Chrysler Factory 6x9s - $17 shipped/pair
2. PG RSD 5CS Grills - $12 shipped
3. Rockford Fosgate P2 10" S8 - $45 shipped
4. GM Headunit Harness and Antenna Adapter - $15 shipped
5. Eclipse CD7000 with the IPC106 (iPod) and GPS105 (Areashot) modules - $300 shipped
6. Eclipse SC6500 component set - $100 Shipped
7. Sony Pro Audio 6" Mids with Matching 2" Tweeters - $35 Shipped
8. Eclipse XA5000 4/5 Channel Amp - $240 Shipped
9. Eclipse EA3532 4/5 Channel Amp - $140 Shipped
Everything is priced with shipping. Everything is OBO except the CD7000 package and the XA5000. Im pretty firm on those, but will listen to reasonable offers. I will consider trades for 18sq ft of MLV, CCF, and SS Damp Pro. Also looking for another 3 way active capable HU (2-way + Sub) with time alignment, 3x 4v+ preouts, and iPod controls/adapter.
Ive had alot of interest in the CD7000. I am willing to split under one condition and one condition ONLY. The CD7000 goes first. I will not ship for a week. If the GPS105 and IPC106 do not sell Ill refund the money. That simple. I have no use for the GPS105 and IPC106 without the HU and no use for the HU without those. If you dont like the terms go somewhere else. In the event that I do get offers for those prices will break down as follows:
CD7000 - $200 Shipped
IPC106 - $65 Shipped
GPS105 - $65 Shipped
PICTURES: Huge For Sale Thread pictures by whitedragon5515 - Photobucket
First up is the Chrysler 6x9s.
Second is the Phoenix Gold RSD5cs Grills1. Product:
4 OEM factory speakers Model 45301S
2. Specs:
4 ohm
15w
6x9's
3. Description/Condition:
Mint. All read 4.1-4.2 on the DMM
4. Price:
$17 shipped a pair
Next is the Rockford Fosgate P2 10" S8.1. Product:
Grills from a PG RSD5cs comp set
2. Specs:
5.25" PG RSD speaker grills
Brand new never installed
4. Price:
$12 shipped for both
Fourth is a GM HU harness and antenna adapter.1. Product:
Rockford Fosgate P210S8
2. Specs:
Single 8 ohm VC
200RMS/400 Peak
2" aluminum VC
Mounting Depth 5.6"
Cutout diameter is 9.25"
60oz. Double stacked magnet
Large roll surround
* Rec. Sealed Box Dims: .65 - .65 cu.ft.
* Rec. Ported Box Dims: 1 - 1 cu.ft
Its in good condition for its age. The basket and motor are near flawless. Not a single chip in the motor anywhere. There are some light scratches on the cone that are hard to see unless your looking at the right angle.
Also comes with the trim ring.
VC reads 7.7-7.8 on my DMM
4. Price:
$45 Shipped
Eclipse CD7000 with IPC106 (iPod) and GPS105 (AreaShot) modules:1. Product:
I have here an antenna adapter and a HU harness. I know for a fact they both work in 97-03 Grand Prixs as thats what it came out of. As far as other compatible vehicles I have no idea. What I did find is:
Harness For select Buick, Cadillac, Chevrolet, GMC, Isuzu, Oldsmobile, Pontiac, and Saturn models, 1985-up
Antenna adapter is for select GM cars from 1988-2006
2. Specs:
Antenna adapter and harness
Used but mint
4. Price:
$15 shipped for both
Eclipse SC6500 Component SetI have an eclipse CD7000 here. Comes with the trim ring, cage, HU brackets for mounting the trim ring, remote, harness, and the rare MEI100 tuning mic. HU has some scratches on the face and a little fading on some of the buttons, but its not to bad.
Also have the GPS105 Area shot GPS module with all wiring and original box. This will allow you to load maps via CD or Magicgate Memory stick and use them for GPS directions turn by turn and with voice prompts. It will also allow you to display on the screen direction, coordinates, or speed of your car.
Last but not least is the IPC106 ipod control module. Allows full speed play back through the HU. Once connected everything can be controlled from the face plate. You can sort by artist, song, playlist, etc. all directly from the faceplate. Also have all the wiring and original box with this.
Heres some pics with an old date. MEI100 isnt pictured. Last pic of how it sits currently in my dash board. Note. The IPC106 and GPS105 are no longer new. They are used in MINT condition with all accessories.
CD7000
GPS105
IPC106
Sony Pro Audio 6" Mids and 2" TweetersThese are absolute mint condition and Im almost positive they are new. The previous owner only had one set installed and I used the used stuff. Comes with flush mounts for the tweeters.
The mids are pretty heavy and whens the last time you saw a mid with a sewn tinsel lead?
# 6-1/2" 2-way Component System
# Power Handling:
* Peak: 450 watts per set / 225 watts each side
* RMS: 150 watts per set / 75 watts each side
# Glass Fiber PMI Woofer
# Rubber Surround
# 1" Silk dome
# Neodymium tweeter magnet
# 4 ohms impedance
# Aluminum voice coil former
# Aluminum cast baskets
# Aluminum phase plug
# Crossover networks included (12 dB/octave high-pass, 6 dB/octave low-pass)
# Linkwitz Riley, Optimum "Q" alignment
# Metalized polypropylene capacitors
# Poly-switch tweeter protection circuity
# Selectable tweeter sensitivity -3 dB/0 dB/-3 dB (0 dB default)
# Audiophile, matched crossover network (speaker specific)
# Black translucent, dust covers
# 10oz. woofer magnet
# Top-mount depth: 2-1/4"
XA5000This is all the info I have on these. If you want T/S specs I can get those for an additional $15 from Meniscus Audio. They are local to me and I have already spoken to them about it. I however havent had it done because I dont plan on using these so the T/S specs are irrelevant to me. I will not pay $15 out of my pocket to get these and have the buyer back out. If these are anything like the old Sony products from the XM or Mobile ES lines these are nothing but SQ mids and tweeters.
I have here some Sony mids and tweeters. Not sure on power handling specs.
Mids are single 6 ohm 6" mids. Appear to be OEM Pro Audio drivers, but may not be. Appears to have a nice woven cone with a **** style dust cap. Nice rubber surround. Model number J14PL10A3's. Both mids read on par as far as coil readings go. Mounting depth is slightly over 3".
Tweeters are single 8 ohm 2" tweeters. Also appear to be OEM Pro Audio drivers. Single 8 ohm with a paper cone. Model number J6PH05A3. Mounting depth is an 1".
Both sets have gold baskets and frames with mounting holes.
Eclipse EA35321. Product:
Eclipse XA5000
2. Specs:
Eclipse XA5000 5-channel car amplifier 50 watts RMS x 4 + 300 watts RMS x 1 at Crutchfield.com
Manual can be downloaded here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/099/099XA1000.PDF
Has some very light surface rubs that can only be seen in the right light. To the ***** eye is perfect.
Internals have never been repaired as far as I can tell.
A very nice under rated amp. The XA2000 is rated for 300@4 bridged, but benched doing 380@4 with clean power.
Heres a nice little review for a comparison:
Eclipse XA2000 Review
4. Price:
$240 Shipped
PICTURES: Huge For Sale Thread pictures by whitedragon5515 - Photobucket1. Product:
2. Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Eclipse EA3532 Pg10
I described this as old school not because of age, but because of age in comparison to Eclipse's amp lineup. This was among some of the first Eclipse amps ever made.
A few small knicks here and there and a few surface scratches. This thing is in great condition for its age. Id give it a solid 9/10 physical and 10/10 mechanical.
From what I can tell its never been repaired. The warranty label was still intact when I got the amp. I broke it to make sure the insides were in one piece after I received it from USPS prior to testing.
This amp was made circa 2003 according to the manual print date.
All I can say is that this thing is very very under rated and pure SQ.
4. Price:
$140 shipped
