[FS] Hifonics HFi2500d
SounDrive
Pro Seller
www.soundrive.audio
Hifonics HFi2500D
10/10 mechanically. Previous owner ran it at 4 ohms on 2 CVRs the entire time he owned it. Never been abused or ran below 1 ohm by me.
There are some scratches on the case. One of the mounting feet is broken, but you can still use the other three and it will be just fine. Gain knob is crooked, but easily adjustable with a small flathead screwdriver.
Code:
HFi Series Single Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohms: 2500 watts x 1 chan.
Max power output: 2500 watts
Pulse Width Modulated (PWM) MOSFET power supply
LED power (blue) and protect (red) indicators
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
Blue illuminated Hifonics badge
Soft start sound function
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, DC, and speaker short protection)
Dual 8 gauge speaker terminals simplify hookup
Heavy duty aluminum alloy vented heatsink for maximum heat dissipation
Silver nickle-plated RCA level inputs
Silver nickle-plated screw terminals
Input sensitivity:
Variable level: 200mV-6V
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Subsonic filter (15-35 Hz)
Damping factor: >200
Frequency response: 15-250 Hz
External 250A fuse required and sold separately
Dimensions: 19-3/4"L x 8-13/16"W x 2-7/16"H
$225 shipped
On me
SounDrive
Pro Seller
www.soundrive.audio
SounDrive
Lebanon, TN
SounDrive
