Sold FS: HELIX DARK BLUE 4 Four Channel - $175 FIRM
sundownz
Pro Seller
Supporting Vendor
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
I WILL NOT TAKE LESS.
NO TRADES, NO TRADES, NO TRADES.
4-Channel amplifier with integrated active frequency crossover for Highpass, Lowpass and Bandpass The Helix Dark Blue 4 is a perfectly equipped 4-channel power amplifier with a high-quality futuristic design. Thanks to their high output power and first-class active crossover technology it can be used in every operating mode.Features such as Bass Boost (0 up to +18dB at 45 Hz) and the variable active crossover for Highpass, Lowpass and Bandpass provide powerfull basses and perfect sound quality. Helix Dark Blue power amplifier is the right choice for young and young-at-heart car audio enthusiasts.
* Power RMS / Musik at 4 x 4Ohm at 13,8 Volt: 4 x 60/120 Watt
* Power RMS / Musik at 4 x 2Ohm at 13,8 Volt: 4 x 100/200 Watt
* Power RMS/Musik 2 x 4 Ohm bridged: 2 x 180/360 Watt
* Total harmonic distortion:
* Signal to noise ratio: > 93 dB
* Bassboost adjustment: 0-18 dB
* Frequency range Highpass: 15 Hz-4 kHz
* Frequency range Lowpass: 40 Hz-4 kHz
* Frequency range Bandpass: 15 Hz-4 kHz
* Frequency range: 10 Hz-30 kHz
* TIM distortion:
* Input sensitivity: 200 mV - 8 V
* Fuse: 2 x 25 A
* Input impedance: 10 kOhm
* Dimensions (H/W/D) in mm: 64 x 245 x 400
* Weight netto: 4,6 kg
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
alius123
