FS: Heat Shrink Tubing
goodstuff
LOL
2,443
Northeast
Heat Shrink Tubing.
4' sections for most, some of it is on spools and I can cut whatever length you need. 2:1 Shrink Ratio. If you are interested, please tell me the sizes, amounts and colors you want and I will get you a shipped price based on the price list below.
Price for each 4 foot section:
3/32 Clear $0.75
1/8 Red $1.00
3/16 Red $1.50
1/4 in Clear, Blue, Black, Red and Yellow $1.75
3/8 in Blue, Yellow and Black $2.00
1/2 Black (shiny pvc type, stiffer than regular polyolefin) $2.50
3/4 in Black and White $3.00
1 1/2 Black $3.50
Refs on Diyma.com under the same name.
Thanks for looking.
I want to buy some, do you have any info on what wire they fit, I need some for 12 ga, 16 ga, 0 ga, and 4 ga.
Hi.
I would use 3/4 for 0 ga, 3/8 for 4ga, and 1/4 for 12 and 16ga. If it's really thick insulation on the 12ga you might want to use 3/8's instead.
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
goodstuff
LOL
goodstuff
Northeast
el_papagallos
