Sold FS/FT Sony 6 Channel amp XM-C2000
jdubbau
Rating: 66.7%
4 2 0
Very cool amp to run a budget 4 speaker system with 8,10,12 sub with great sound quality for what it is. Will also run 6 channels for a Front Stage 3 way set up or many other configurations.
In great condition 8/10 cosmetic 10/10 mechanical No issue at all and comes with everything you need to get up and running.
$125 shipped Con Us OBO !!! Make an offer if you dont like my starting price and I am open to trades on this and the Epic 160 I have up for sale. I need a high end EQ trunk mount or in dash digital eq. I am also open to SQ amps, DVD in dash, Comp sets and maybe some other stuff just let me know.
I dont think it can be bypassed as it does have a switch on the bottom of the amp to do 2/3 way crossover but other than that the rest of the settings and crossover info is in the pics listed in the ad. Still $100 for a 6 channel amp that could be a 1 amp solution for someone or a heck of a 3 way or 2 way amp. And oh it has pretty good specs too!!
Ok REALLY GOOD SPECS
Puls power supply circuitry
Maximum power at 4 ohms
LESS than 0.005% 4 ohms!!!
Subwoofer line ouput less than 0.003%!!
Input level adjustment range .2-2v
Signal to Noise ration
MORE THAN 108db!!
Max output
65wx2 High/front speaker
65x2 Mid range/rear speaker
Sub Stereo 65w x 2 or monaral 200w
Rated output
30w x 2 High/front
30 x 2 Mid/Rear
Sub Stereo 30x2 and monaural 80W
Crossover Freq
High/mid range 3.5kHz, 5kHz, 7kHz
Front (2way only)
HPF 70Hz, 100Hz, 140 Hz
Mid/Rear
sUB WOOFER
LPF 70Hz, 100Hz, 140 Hz
Sub-woofer line output
LPF 70Hz, 100Hz, 140Hz
Crossover slope
12dB/oct (crossover Point)
6 dB/oct (front, Mid,/Rear HPF)
18 dB/oct (Sub-wooferLPF)
Definatley not one of there pieces of the NEW AGE.
The sound is spectacular and I think it is a lil underated too. For a $100 you just cant go wrong? Still dont know why I still have it as I thought this was a steal for 6 channel amp with multiple uses and good specs.
jdubbau
jdubbau
evansville In
jdubbau
