FS/FT: Phoenix Gold Tantrum 500.2, American Bass SQ500
WashYourWinky
The Pilot
I would like to trade for a head unit. Must have USB and at least two pre amp outs.
Will ship USPS, UPS or Fedex.
Sell for:
Tantrum $130 shipped in the US
SQ500 $40 shipped in the US
D6 $220 shipped in the US
Tantrum 500.2 Specs:
Mechanical 10-10 Cosmetic 8.5-10
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA or Speaker Level Inputs
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
18dB / Octave High Pass or Low Pass Crossover
40Hz to 800Hz Continuously Variable Crossover Frequency
Auxiliary Outputs Route Inverse Crossover Signals
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
Optional LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
Amplifier Type: 2-channel
RMS Power: 125W x 2 @ 4 ohms
RMS Power: 250W x 2 @ 2 ohms
Bridged RMS Power: 500W x 1 @ 4 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
SQ500 specs:
Mechanical 10/10 Cosmetic 7/10
Power Output (DC 14.4V):
RMS AT 4 OHM, MONO 130Wx1CH
RMS AT 4 OHM STEREO 50Wx2CH
RMS AT 2 OHM STEREO 80Wx2CH
* MAX POWER 500W
* S/N RATIO >100DB
* THD 0.02%
* CHANNEL SEPARATION >55DB
* INPUT SENSITIVITY 0.15V-5V
* INPUT IMPEDANCE 47KOHM
* SLEW RATE 10V / USEC
* DAMPING FACTOR 200 AT 4 OHM
* FUSE RATING 20A
* DIMENSIONS(mm)
* WIDTH 9.6
* HEIGHT 2.2
* LENGTH 7.1
Diamond D6 1000.1
Mechanical 10/10 Cosmetic 9/10
D6 Series Monoblock Amplifier
RMS Power Rating:
250 Watts x 1 Channel # 4 Ohms
500 Watts x 1 Channel # 2 Ohms
1000 Watts x 1 Channel # 1 Ohm
Massive Proprietary Heatsinks
Wired Remote Level Control Included
Nickel Plated Solid Brass, Circuit Board Mounted Terminals
4 Gauge Direct Power / Ground Terminals
10 Gauge Direct Speaker Terminals
Fully Adjustable Mounting Feet
Advanced Protection Circuitry
Adjustable Input Sensitivity: 200mV - 5V
Low-Pass Filter: 50 Hz - 250 Hz, 24 dB/Oct.
Subsonic Filter: 15 - 40 Hz, 12 dB/Oct.
Phase Switch: 0° / 180°
Dimensions: 11-1/2" L x 12" W x 2-3/4" H
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
