FS/FT Kicker KX250.2
97srad750
Kicker KX250.2
Used
90.00/shipped
Would prefer to trade for something decent 2 ohm mono stable. I don't have the birthsheet, but it was 300 and some change at 4 ohm mono. No bass knob either.
Specs
Signal-To-Noise Ratio 95 dB
Max Output Power / Channel Qty 125 Watts x 2
Input Channel Qty 2
Amplifier Output 2-channel
Output Channel Qty 2
Input Signal Voltage 0.17 - 5V,
0.34 - 10V
Crossover 2-way active crossover
Crossover Slope 12 dB/octave
Low Pass Frequencies 50 - 200 Hz
High Pass Frequencies 50 - 200 Hz
Bass Boost Frequency 40 Hz
Bass Boost Gain 0 to +18dB
Amplifier Output Details 125 Watt - 2 Ohm - 2 channel(s),
250 Watt - 4 Ohm - 1 channel(s)
What are the subs you are wanting to push???I have quite a few amps that I can see if will work for you?? Most I have are a little more than the 90.00 range that I have in them,,,,But ?????Pm me and see what we can do,and what youd like that I have and maybe trade??Thanks
I will be checking my Pm from time t time.I am working today,so the response here will be delayed.Thanks.Pm me if you would like to trade.I have some nice powerful amps that should work for you???????Thanks
97srad750
97srad750
Lexington, SC
audiobaun
