FS/FT: Crossfire BMF600.2
basscort2009
Banned
crossfire bmf600.2
item is only 4 months old got it from crossfire directly brand new. still have original boxs and manuals for it. its in 9/10 cosmetically and 10/10 mechanically. it has 3 30 amp fuses!! lots of power //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SPECS:
RMS Power Rating: (12.5V)
4 ohms: 150 watts x 2 chan.
2 ohms: 300 watts x 2 chan.
Bridged, 4 ohms: 600 watts x 1 chan.
High efficiency MOSFET power supply
LED power (green) indicator
Variable Bass Boost (0 to +12 dB at 45Hz)
Soft Start, on/off circuitry
Multi-stranded power toroid
High-efficiency Bipolar output transistors
Variable high-pass and low-pass electronics crossovers
2/1 channel operation
Preamp RCA outputs to daisy chain multiple amps
5-Way System Protection circuitry
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Input sensitivity:
Low level: 0.15V-6V
Full-range crossover filter
Variable high-pass filter (50-250 Hz)
Variable low-pass filter (50-250 Hz)
Dimensions: 14-9/16"L x 8"W x 2-3/8"H
200 shipped. ONLY TRADES: 2 matching 4 channels.
via fedex
for username purposes
basscort2009
Banned
basscort2009
dallas tx
basscort2009
