Sold FS/FT-BNIB two channel amp
ChargerBoy23
Up for sale or for trade is a BRAND NEW still in box/wrap Power acoustik bamf 2 channel amplifer 2600 max power amp. It goes online for 200+ shipping. I will do 150 shipped firm. I would prefer paypal. I would be willing to trade for 6x9s+ cash or a smaller 4 channel amp. Here are the specs
Power Acoustik's BAMF amplifier series is the perfect amplifier for those that are looking for quality performance, while wanting to save some cash. Each amplifier in the BAMF series feature a die-cast aluminum heat sink that dissipates heat from three sides of the amplifier. For convenience, all the connections and control functions can be found on one side of the amplifier. • BAMF Series 2600W Max 2-Channel Class AB Amplifier • RMS Power Rating: æ 4 ohms: 450 watts x 2 chan. æ 2 ohms: 540 watts x 2 chan. æ Bridged, 4 ohms: 1080 watts x 1 chan. • Max power output: 2600 watts • MOSFET power supply • Wired remote bass level control included • Power and Protection LED power indicators • Adjustable Tuned Bass EQ (0-12 dB Bass Boost) • PWM Circuitry • Full Selectable Crossover (HI,Full,Low) • Three-way protection circuit • 2-Ohm Stable stereo • Tri-mode capable • System Distress Indicator • Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier • Platinum RCA level inputs • Platinum screw terminals • Variable high-pass filter (50-500 Hz, 24 dB/octave) • Variable low-pass filter (30-250 Hz, 24 dB/octave) • Subsonic Filter: 15-50 Hz • Signal to Noise Ratio: 97 dB • Frequency response: 10-30000 Hz • Dimensions: 9-1/4"L x 17-1/4"W x 2-1/4"H
ChargerBoy23
ChargerBoy23
Jackson MS
ChargerBoy23
