Sold FS/FT Blown SAZ-3000
bumpin buick
Science is everything
I saw another one up here and it looks like hes having luck so I will post up mine as well. The case on mine is a little scratched up and I can get pictures when I get home. I have pulled the back off and the fets are all in perfect shape, no burn marks nothing appears to be blown as far as the fets go. The issue is someone tried stealing this out of my car. In the process they bent the power and ground connections, they are bent up at an angle. My assumption all though its not visiable is that the connection to the power supply is bad. Chris at DB-R had quoted $200 for a fix, said it could be cheaper or could be more. Amp worked flawless up until that point, if you try hooking it up now, it wont let you start the car, I tried having the car on first then connecting the remote and it turns the car off, so my assumption is there is a short in the power supply.
It is an old style heatsink but board really looks flawless, case would be great if repainted but does have some scratches.
I will take $300 for it or open to any trades as well. Pics up tonight and if anyone needs refs I have a few;)
I saw another one up here and it looks like hes having luck so I will post up mine as well. The case on mine is a little scratched up and I can get pictures when I get home. I have pulled the back off and the fets are all in perfect shape, no burn marks nothing appears to be blown as far as the fets go. The issue is someone tried stealing this out of my car. In the process they bent the power and ground connections, they are bent up at an angle. My assumption all though its not visiable is that the connection to the power supply is bad. Chris at DB-R had quoted $200 for a fix, said it could be cheaper or could be more. Amp worked flawless up until that point, if you try hooking it up now, it wont let you start the car, I tried having the car on first then connecting the remote and it turns the car off, so my assumption is there is a short in the power supply. It is an old style heatsink but board really looks flawless, case would be great if repainted but does have some scratches.
It turns the car off wired never seen that happen before.. Shit just hook the amp up when u get out no one could take the car.. lol Sundown theft devise.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Not 100% sure but another friend on my site had suggested ...
"probably the diode between the power and the ground which is blown(shorted). This happens alot when amplifiers are being stolen. The Diode is almost the only way an amplifier can draw enormous current without working or smoking."
he knows what hes talking about so I will assume he is right.
bumpin buick
bumpin buick
Appleton, Wisconsin
bumpin buick
