Sold FS/FT Amps! Alpine, Rockford, SPL.
WashYourWinky
The Pilot
Things I would trade for:
12" sub
15" sub
head unit with mp3 support
A PCI-e video card
6.5" comps
More pics available.
Rockford Fosgate Punch P325.1 Mechanical 10/10 Cosmetic 7/10 NO END CAP $90 shipped
Specs:
# 325 watts, Punch Series Monoblock Amplifier
# RMS Power Output:
* 4 Ohms: 175 watts RMS x 1 chan.
* 2 Ohms: 325 watts RMS x 1 chan.
# Variable high- and low-pass filters (40-400 Hz, 12 dB per octave)
# Wired Punch Bass EQ (0-18 dB at 40 Hz)
# Focused Mass Heatsink design
# Removable connector cover
# Special-design TO-247 MOSFETs run cooler than standard transistors
# CEA-2006 compliant
# Preamp inputs and outputs
# 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 11-3/4"W x 2-1/8"H x 11"D
I also have a MTX RT2200x to trade.
Specs:
Output Power at 12.5V:
2 x 100W @ 4 ohms (
2 x 200W @ 2 ohms (
1 x 400W @ 4 ohms bridged (
S/N Ratio: 100dB A-Weighted
Damping Factor: >200
Freq. Response: 20 - 20KHz ±.25dB
Fuse: 2 x 30A
Dimensions: 8" x 9" x 2" (20cm x 22.8cm x 5cm)
Alpine MRP-M500 Mechanical 10/10 Cosmetic 7/10
SPL Z2X-1600 Mechanical 10/10 Cosmetic 9/10 Minor scratches. $110 shipped
I have a good condition RAZR2 from T-Mobile here with a charger if you are still looking for one. What is it worth to you? I see a thing or 2 on your for sale list I like, but who knows.
Best way to contact me will be email (JLAudioCavalier@aol.com). thanks
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
