Put it in my car and its only been seeing power for a few days now. Decided I dont want to go with a 10. Its everything you could expect out of a 10. Great woofer. If you dont know about RE just do a search on here and you'll learn everything you could possibly want.
RE's site: http://www.REAudio.com
specs:
Mounting Depth - 6"
Mounting Hole Diameter - 9.25"
Overall Diameter - 11"
Bolt Hole Circle - 10.125"
Motor Width - 6.5"
Motor Depth - 3.25"
Basket Depth - 2.75"
Displacement - 0.15 cu. ft.
Weight - 23 lbs.
Electrical Q Value -Qes: 0.29
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.27
Free Air Resonance -Fs: 30.7 Hz
Equivalent Compliance -Vas: 21.8 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 85.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
For sale: without enclosure 210 + shipping. with enclosure 240 + shipping
For trade: looking for a single 12, maybe a single 15 let me know what ya got
specs:
Mounting Depth - 6"
Motor Width - 6.5"
Motor Depth - 3.25"
Weight - 23 lbs.
