I bought this amp because I was considering a 5.1 system. changed my mind when my stuff got stolen so f/s and unused. Would like $300 shipped. very big and heavy powerhouse amp with some very cool features.
http://www.cardomain.com/item/HIFZX51DIGITAL
Features
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 50W x 5 + 200W x 1
THD at 4-Ohm RMS Power: 0.05 %
Bridged RMS Power @ 4 Ohms: 130W x 2 + 300W x 1
Speaker Level Inputs: No
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: None
Frequency Response: 10-30,000 Hz
Signal to Noise Ratio: >95 dB
Fuse Rating: 3 x 30 amps
6 channels of discrete amplification
Built-in digital surround processor
Dolby Digital 5.1 decoding
Dolby Pro-Logic mode
4.1 Phantom surround mode
Toslink optical & RCA coaxial digital inputs
Auxiliary 2-channel RCA inputs
Full on-screen display (OSD) with graphic menus
Composite RCA video input & output
NTSC / PAL video selector
Variable 12 dB/octave high-pass crossovers (30-1200 Hz)
Variable 24 dB/octave low-pass crossover (20-220 Hz)
Wired 16' (5m) remote sensor eye & handheld slim remote
High-current molded power & speaker terminals
5-channel RCA inputs
Test tone generator
24-bit A/D & D/A converters
Remote turn-on output for additional devices
New 20th anniversary HiFonics heat sink
Blue backlit Dolby logo
Exponential Vari-Power Supply (EXVP)
PWM Mosfet circuitry
It comes with the box and the amp, no other accessories are included. The remote control and receiver for the surround sound are not included. If you do not have these, the surround sound wll not function. You can purchase them However, the amps still works perfectly as a 5.1 channel amp. It's very similar to the 5ch ZX8000 amp, except its got an extra channel. No hard copy of the manual, but it can be downloaded at Hifonics website:
http://www.maxxsonics.net/manuals/hi...leVideoAmp.pdf
Would consider a trade for an xbox360/ps3 or maybe a laptop. Dont need any car audio. Will entertain offers.
Im sure someone likes the optical and coaxial inputs. FYI, if you do plan to purchase the remote control and use the on screen display, this unit has time alignment and level control.
Features
Preamp Outputs: No
Bass Boost: None
Test tone generator
