FS: Focal Dual Monitor FP - $1100 OBO !!!
This is a USED amplifier. Tested to work on our bench. Does not carry further warranty but will work when you receive it.
This amplifier hooks to your PC through a USB cord for detailed EQ and crossover adjustments!
Comes with software, USB cord, remote, remote cord, manual, and original box.
Focal FP Dual Monitor
* Output POWER @13.8 VDC; THD 1.0%
o 2 x 4 Ohm 300W x 2ch
o 2 x 2 Ohm 400W x2ch
o 1 x 4 Ohm 800W x 1ch
o 1 x 2 Ohm 1200W x 1ch
* Smallest output Impedance:
o Stereo: 2 x 1 Ohm
o Bridge: 1 x2 Ohm
* Frequency characteristic: 10Hz~45kHz
* SIGNAL-TO-NOISE RATIO ratio: Above 110dB
* Damping factor: 600 or more
* Input sensitivity : 0.2V~5V
* Converter: 24bit/96kHz crystal
* Digital graphics EQ: 30 bands (1/3oct)
* Digital parametric EQ: 1 band full adjustments
* Digital delay line (every input/output ch): 2 input /2 output maximum of 2048 samplings
* Digital control: Outside it minds USB PC (Windows)
* High pass crossover: Adjustment of the slope and frequency is possible
* Low-pass crossover: Adjustment of the slope and frequency is possible
* Remote control: Attachment (master volume +5 pre-setting)
* Supply voltage: 11~15V
* Size (width x depth x height): 540 x 280 x 50mm
* Weight: 7.5kg
o Stereo: 2 x 1 Ohm
o Bridge: 1 x2 Ohm
* Weight: 7.5kg
