Sold FS: F#1, Brax, Arc, etc.
jay spec
CA
So after mulling it over for several weeks, i've decided to downgrade on my next install, so i have the following available:
Alpine F#1 7990 - like new, 10/10 $1300
Brax x1000 - like new, 9.5/10. never been powered. black finish. only thing is a surface scratch on the name plate $550
Brax x2000 - like new, 9.5/10. never been powered. silver finish w/ polished name plate. only thing is a smudge mark or two from test mounting $1000
Brax x2400 - like new, 9.5/10. never been powered. silver finish w/ polished name plate. only thing is a smudge mark or two from test mounting $1100
Arc Audio 2500xxk - nib, 10/10. never been powered. $500
all prices + shipping/paypal.
i post mostly over on elitecaraudio.com and have references there. i also do alot more reading than i do posting //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
WOW.
Excellent equipment, would be a dream of mine to own them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Pics would be cool, just so I could marvel at them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
NG
i bought all the equipment for competition this season before i even decided on what car it was all going into. unfortunately, the car i ended up with was an '06 325i, which is not the most friendly of cars when it comes to aftermarket audio. therefore, i won't be competing this year (probably not next either), and will just do something simple i.e.- cleansweep or possibly the new oem integration unit alpine has coming out.
i'm waiting for my digi's battery to charge before i can get all the pics taken, but here's a teaser:
name's jon (or jay) //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
specs for the x2000 and x2400 can be found here:
http://www.audiotec-fischer.com/englisch/produkte/brax/endstufen.html
and here a copy/paste of the x1000 specs:
Specifications
Model x1000
Description 2-channel Amplifier
RMS Power (4 ohms) 100W x 2
RMS Power (2 ohms) 195W x 2
RMS Power (1 ohms)) 295W x 2
RMS Power Bridged (4 ohms) 375W x 1
RMS Power Bridged (2 ohms) 550w x 1
Stable Into (stereo/mono) 1 ohms / 4 ohms
Total Hamonic Distortion(THD) 0.002%
Frequency Response (+/- 0.5dB) 20Hz - 20kHz
Signal-to-Noise (A-weighted) >105dB
Input Sensitivity (low level) 180mV - 4.8V
Bridgeable Yes
External Fuse Size 60A
TIM Distortion 0.016%
Input Impedance 10 kohm
Damping factor at 4 ohm >400
Net Weight 5.9kg
Height 5.30 cm
Width 23.80 cm
Length 38.10 cm
Specifications
Model x1000
Bridgeable Yes
Net Weight 5.9kg
Height 5.30 cm
Width 23.80 cm
Length 38.10 cm
Close....John:) I thought the x1000 was a 2 channel, but wasn't sure of its power. Are those specs at 14.4? BTW, I still have the Alumapro if you are interested //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That F1 would put me in Modified+, **** MECA //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
On the other hand, I'd probably win every show I entered around here, there's no one in that class //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
fox, i don't know if it's 14.4v or not. i also think you might have me confused with someone else as i don't remember ever inquiring about alumapro before.
jim..just think of all the trophies....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ok, sorry. I thought you were jaybo on the Zapco forums.
jay spec
jay spec
CA
jay spec
