FS: Exodus Anarchy midbass like new
UMWDawg92
I have a pair of Exodus Anarchy midbass drivers 8ohm
2 Exodus Anarchy 6.5 midbass
The infamous Anarchy midbass, they are about as beastly of a 6.5 mid that you will find 12.5mm of one way xmax. Low distortion XBL2 motor. Can play easily up to 3khz in a 2 way setup and be highpassed as low as 50hz and still take a lot of power. These are monsters, close to 4inches deep.
These are originals from diycable/exodus audio. I used them for probably about a month after I bought them. I then got a different car and these would not fit in the doors. They have been in storage ever since.
T/S specs
8 Ohm model:
Re: 6.4 Ohm (for 8 ohm model)
Le: 0.84mH
Fs: 45.8Hz
Qms: 6.37
Qes: 0.48
Qts: 0.44
Mmd: 29.4
Mms: 30.25
Cms: 0.4mm/N
Vas: 9.61L
Sd: 131 cm^2
BL 10.79
SPL: 84.7 dB/1W/1m
Xmax 12.5mm
$100 shipped for the pair
On me, probably fedex.
UMWDawg92
UMWDawg92
Missoula, MT
UMWDawg92
