Sold FS: Everything must go: Rainbow Vanadium, Memphis Belle, Diamond Audio D6, & more
randyrsx
Well I bought a house and priorities have changed to furnishing that instead of my beloved RSX. All prices include shipping...
Rainbow Profi Vanadium Kickbass (2-way) SOLD
Memphis Belle *big belle* old style with the plane in the upper-left hand corner.
Includes subwoofer gain knob.
# User Selectable 12dB or 18dB Per Octave Crossover Slope
# Built In Fully Variable Sub-Sonic Filter on channel 5
# 5-Channel MClass Series Amplifier
# Class-AB / Class-D Hybrid Amplifier
# Compact Aluminum Chassis with Chrome Finish
# Gold Plated RCA Connectors
# Full MOSFET Design
# Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
# Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
# 4-Way Protection Circuitry
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# Optional Wired Remote Gain Control
# Adjustable Input Sensitivity: 200mV - 4V
# Dimensions: 25.81" L x 7.6" W x 2.4" H
# Number of Channels 5
# RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan.
# RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan.
# RMS Power (1 ohm) Stable + 1100 watts x 1 chan.
# Bridged RMS Power 230 watts x 2 chan.
# Peak Power Output 3120 watts approx.
# Min. Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5)
# Min. Impedance Bridged 4 ohms
# THD @ Rated RMS Power 0.03 %
# Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz) + LP (50 - 250 Hz), Subsonic (20 - 50 Hz)
# Signal-to-Noise Ratio 95 dB
# Fuse Rating 30A x 6
$450 obo
Diamond Audio D6 subwoofers *dual 4* (I have two of them and like to sell as a pair.
* Power Handling NOM/MAX: 1000 watts MAX, 500 watts RMS
* Sensitivity (2.83V/1m): 84 dB SPL
* Freq. Response: 23-250
* Type: Dual voice coil
* Size: 10 in.
* Mounting Depth/Diameter: 5.6 in. / 9.2 in.
* Alloy Driver and Ferrite Magnet
$175 (for the pair) obo
The box obviously I'd like to see go as welll. It was built by BJ Fisher here on this forum. The dimensions are 40" x 16 x 13 1/2". It's 2.5 cbft after displacement tuned to 32hz.
$125 obo
If you wanted the two subs and box together, I'd knock down the price.
AudioControl Matrix: BNIB
Six channels of input and output
24 dB of signal gain 13 volts peak output
12 dB of signal attenuation
subsonic filter
Output level controls
Balanced differential inputs
Linkable inputs 2 input channels to 6 output channels
Low impedance outputs
Voltage indicator LEDs
$115 obo
Bash 500watt plate amp: BNIB
BASH patented amplifier technology was developed to offer extreme amounts of power without the wasted heat and energy of traditional amplifier designs. Add to this an intelligent circuit design, and you get benefits such as extremely low distortion and high signal to noise ratios. The combination of clean output and high power makes the BASH amplifiers some of the best sounding subwoofer amplifiers on the market.
Features: 50 to 150 Hz low-pass crossover, 0 degree or 180 degree phase, line level inputs, speaker level inputs, line outputs, master on/off switch, auto on.
Specifications: 500 watts RMS @ .5%THD into 4 ohm load. Signal to noise ratio 105 dB A-weighted, Dimensions: 12" W x 8" H x 3-1/2" D.
* High power output in a compact, lightweight design
* Speaker and line level inputs for connection to any stereo
* Limiting circuit prevents audible clipping and protects woofers
* Auto On/Off and phase reversal switch
$175 obo
Dayton Audio 15" home subwoofer: BNIB
The Dayton Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
Specifications: *Power handling: 500 watts RMS/800 watts max *VCdia: 2-1/2" *Le: 1.00 mH *Impedance: 4 ohms *Re: 3.3 ohms *Frequency range: 18 - 800 Hz *Fs: 18 Hz *Magnet weight: 150 oz. *SPL: 90 dB 2.83 V/1m *Vas: 9.55 cu. ft. *Qms: 3.10 *Qes: .49 *Qts: .42 *Xmax: 14mm *Dimensions: A: 15-5/16", B: 14-1/8", C: 6-1/8".
$125 obo
If you pick up the plate amp and dayton subwoofer together I'll throw in two precision ports.
Please remember that all prices include shipping so don't throw a low offer, the house isn't done until February, I can wait.
PM Me!
Refs: bjfish11, jjones5000, damaso87
ebay: randyproch
randyrsx
randyrsx
Behind you!
Kagymp5
