FS: Eclipse XA4000 4chan amp
nickpapa
Eclipse XA4000 4 channel amp
Great condition. One slight scratch next to dials (see pic), but other than that very clean. I've had an issue where my rear channel (where my sub was hooked into) would stop working and I would have to put the volume up loud for it to kick in. It would then play like normal. Not sure if this was an issue with the rear channels or the sub itself but wanted to be honest. Great sounding and powerful amp!
Specs:
125 watts RMS x 4 at 4 ohms (175 watts RMS x 4 at 2 ohms)
350 watts RMS x 2 bridged output at 4 ohms
variable high-pass filter (30-500 Hz, 18 dB/octave)
variable low-pass filter (50-500 Hz, 18 dB/octave)
variable bass boost (0-8 dB at 32-64 Hz)
subsonic filter (18 Hz, 18 dB/octave)
ICEpower® full-range Class-D amplifier design
MOSFET power supply
fuse rating: 30A x 3
4-gauge power and ground leads
15-3/4"W x 2-5/16"H x 10-1/4"D
$200 shipped
FYI. I had a similar problem with an XA5000. Turns out that spraying the switches with electronic cleaner solved the issue. Apparently the switches get gummed up with dust/dirt and don't make good contact after a while.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
802
nickpapa
nickpapa
Northern NJ
bumppinKota
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
