Sold FS: dual opteron motherboard
_DjScrew_
CPU
• Supports Single CPU (Socket 940) for AMD® Athlon-64 FX 51 series or Opteron 100 series (1-way) or Opteron 200 series (2-ways) CPU.
• Supports Dual CPUs (Socket 940) for AMD® Opteron™ 200 series (2-ways) processors and up (SledgeHammer DP)
Chipset
• VIA® K8T800™ Chipset
- 800MHz HyperTransport FSB
- Support for AGP 2X/4X/8X/Pro
- Ultra V-Link 1.06GB/s high bandwidth North/South Bridge interconnect
• VIA® VT8237™ Chipset
- A 33MHz/32bit PCI 2.2 compliant bus interface supports up to 6 external devices.
- Dual Channel Serial ATA/RAID (0, 1)
- Dual Channel ATA 33/66/100/133
- USB 2.0, 6 ports, UHCI compliant
- Advanced power management capabilities
- Including ACPI/OnNow
- LPC bus to connect peripherals such as super I/O and BIOS.
- IO APIC controller.
Main Memory
144-bit DDR at 200, 266, 333MHz, 400MHz.
• Supports DIMM sizes from 64MB (128Mb x 16 DRAMs) to 2GB on each DIMM slot.
• Supports 4 DDR DIMMs upto 8GB (Registered Memory only)
• Supports interleaving memory within DIMMs.
• ChipKill ECC allows continuous correction of 4-bit errors in a failed x 4 memory device.
• For Single AMD® Athlon-64 FX 51 series, it will support Registered Memory up to DDR 400
• For Single orDual AMD® Opteron Series, it will support Registered Memory up to DDR 333
asking 150shipped, it dosen't include the rear plate that you screw into the case for the connections. any questions, just ask. but don't ask for pix, that's a no.. but there are refs
_DjScrew_
_DjScrew_
omaha, nebraska
_DjScrew_
