Sold FS: DLS Iridium Tweet, Mid, A3 amp
MrDave
My friend who recently did a DLS install on his car is upgrading some stuff. He put the stuff in the car a month ago, so it is all literally brand new.
Original boxes and everything. I could take photos, but he is not here right now for me to do so. Either way, stuff is flawless.
$150 for each pair of mids or tweets, that's it. SOLD
$300 for the A3, that's it.
This amp is stable down to 1ohm and can put out 1200RMS. Because a few people haev asked, this amp was bought authorized from Don Amann of Unexpected Creations.
Cheap, yes. He wants it gone.
Couldn't pull the equipment from the car, so this is the best I could do for now.
I'm not sure you folks realize how sexy this amp is for the price...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
MrDave
MrDave
Mahopac, NY
MrDave
