Sold Fs: Dls A5
-=GS=-
This has been a great amplifier, I bought it here on the forums. It works perfectly and I have never had any problems with it. The top edges of the amp are slightly bent, they were this way when I bought it. Could most likely be straightened. I never tried because I had it mounted under a seat.
$275 + Shipping
* RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
* Mode : AB
* Number of channels : 3
* Output power in 4 ohm : 2 x 85 W
* Output power in 2 ohm : 2 x 100 W
* Mono channel, ouput power in 4 ohm : 300 W
* Mono channel, output power in 2 ohm : 500 W
* Mono channel, output power in 1 ohm : 780 W
* S / N ratio, A-weighted : > 100 dB
* Damping factor : > 200
* Input impedance : > 10 kohm
* Input sensitivity, variable : 0,2 - 7 V
* Filter, front channels : Highpass: 50-125 Hz
* Filter, mono channel : Lowpass: 40-90 Hz. Subsonic: 25 Hz
* Phase shift control 0-180 degr. : Yes
* Remote sub level control with phase control : Yes
* Terminal for external cooling fan : Yes
* Dual DC-inputs : No
* Current draw, idle : 0,5 A
* Current draw, maximum : 90 A
* Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
-=GS=-
-=GS=-
Houston
-=GS=-
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
