Sold FS: Directed 1200t (Arc 1500D-R board) 1000w RMS 2 channel
ealvar
Heavily rusted
Selling a lightly used, with box, Directed 1200t 1000w 2 channel amp. This amp was designed by Robert Zeff for Directed Electronics and is a Class T tri-path amp with multiple power rails. It is essentially the same amp as the Arc 1500D-R (ampguts here for comparison), also designed by Zeff but Directed added an additional impedance mode, top panel controls, BIT Writer interface, and fan controls. Due to it's multiple impedance modes it has several power configurations.
* 225x2 @ 4ohm (high impedance mode)
* 450x2 @ 2ohm (high impedance mode)
* 900x1 @ 4ohm bridge (high impedance mode)
* 150x2 @ 4ohm (low impedance mode)
* 275x2 @ 2ohm (low impedance mode)
* 1000x1 @ 2ohm (low impedance mode)
* S/N: > 98 dB
* Freq. Range: 20-20kHz
* Damping Factor: > 200
* Input Sens.: 150mV to 8V
* Crossover: var. 12dB 2-way
* Variable Bass EQ: 0 to 12dB
* Variable 20-50Hz subsonic filter
* 24dB slope in mono lowpass operation
* RCA Output: Yes, stereo
Photos here.
Manual in PDF format here.
$160 shipped.
I also have a second 1200t that goes into protection. I'll include it for $15 more if you want it for parts or to try and repair.
As for references I sold quite a few things back on rec.audio.car (tons of Xtant and Directed amps), my ebay username is ema425. I can probably dig up some email addresses for an Infinity 311a I sold a few weeks ago locally, and a DEI-204 active crossover I sold about a month ago.
any intersted in tradin for some 1/0awg wire pm me if u are
Sorry, I have too much 0/1 as it is //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The only trade I'd be interested in is a 12" D4/D1 ~500w RMS sub like a DIYMA, RL-p, SI Mag, Fi Q, etc.
I won't sell the 1200t that goes into protection separately. Not worth it to pack and ship it separately.
Thanks,
E
Sorry about the crappy pictures. My digi-cam battery needs to be recharged so I had to use my phone camera. I'll try and get some higher quality pics up this evening.
Do you have the Bitwriter and if so, have you changed any of the default valet or turn-on delay settings? Also curious about what the default settings are if you have that info. Thanks.
Nope, never used the Bitwriter and I'm the only owner. Not sure what the defaults are. I've always wanted to play with the Bitwriter but never got around to getting one.
ealvar
Heavily rusted
ealvar
Tacoma, WA
ealvar
