FS: Digital Designs S4a w/Original Box
$LICK CALIFA$
Not Far!
Item(s) for Sale: Digital Designs S4a w/Original Box
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct Channels 1-4
Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct Channels 3-4
Clipping Display LED
Tested Voltage 14.4
Cont Power at 4 ohm 100W x 2ch + 200W x 2ch stereo
Cont Power at 2 ohm 150W x 2ch + 300W x 2ch stereo
Cont Power at 1 ohm 175W x 2ch + 350W x 2ch stereo
Damping Factor >550 @ 2 ohm
Cont Power at 4 ohm Bridged 300W x 1ch + 600W x 1ch Mono
Cont Power at 2 ohm Bridged 350W x 1ch + 700W x 1ch Mono
Dynamic Power 400W x 1ch + 800W x 1ch
Efficiency thru Output >64%
Dimensions - mm 420L x 232W x 63.5H
Dimensions - inches 16.54L x 9.13W x 2.5H
Signal to Noise 95 dB
Like new S4a bought it used w/the box but never powered up except to test that it worked and now for pics. No scratches, dings, or dents. Comes w/both allen keys too.
Cosmetic 9.5/10 Mechanical 10/10
Price: S4a - $400+ actual shipping (buyer chooses shipping provider)
ABSOLUTELY NO TRADES!!!
how would this compare to say a rockford 1000/4?
didn't mean to ignore u I just saw your post...
honestly couldn't tell u in sq but they're both powerful 4 channels. The s4a is staggered with about 1050 watts rms total power while the fosgate is a balanced power amp w/1000 watts of total power, although fosgate does underrate their amps so look for more power there. Both 2-ohm stable bridged, s4a has smaller footprint though, overall you can't go wrong with either imo...
ohh man bump for an amp I want
Buy It!
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
Decebal
    Jun 10, 2024
