Sold FS: Diamond D7056 Amplifier, Like New! - $500 Shipped OBO
EFFENDI
I have a Diamond Audio D7056 6 channel amp available for purchase. Part of the infamous D7 series of amps that are pretty much the best amplifiers Diamond Audio has ever made.
Specs as follows:
RMS Output Power
50 Watts x 6 @ 4 Ohm Stereo
100 Watts x 6 @ 2 Ohm Stereo
200 Watts x 3 Bridged @ 4 Ohms
Frequency Response: 3-50,000 Hz
Signal-to-Noise Ratio: 102dB
THD: 0.02%
Channel Separation: 80dB
Length: 22 3/4"
Width: 10 5/8"
Height: 3"
This is really an awesome amplifier and I hate to have to part with it. I have less than 20 hours of play on it. Shipped package will include manual, birthsheet, and all retail packaging (box).
I am asking $500 shipped. This amplifier was purchased brand new from Diamond's factory, (it is not refurbished like some on eBay) and does have warranty coverage. Price is somewhat negotiable, as I would like to sell this ASAP.
Model number is D7056, even though birthsheet shows otherwise, this was simply a QC error. Be assured, this is a genuine D7056.
You most definitely can use them with this amp. Just hook them up using the amplifier's built in crossovers, (don't use the factory-supplied passives) it should be more than enough power. I ran a set of DLS 6.3 Ultimate Iridiums with this amp and they sounded absolutely beautiful.
You are talking about running the front stage active, using 4 channels of the amp, correct? Problem is, I need to run my rear speakers as well. I have an Eclipse AV-8132 in that vehicle and it has no built in power. I am trying to set up a 5.1 system and need the rear speakers for surround.
I'd reccomemend you run everything active if you can, expecially if you are doing 5.1. And yes, that is what I am talking about //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. You can use the remaining 2 channels to run the rears and then buy another mono/2 channel amp for your center channel setup.
EFFENDI
EFFENDI
Los Angeles, CA
EFFENDI
