Bought some used DA175-8 7" woofers and tweeters a while back that I had planned to use on a DIY home stereo. I ended up getting a crazy good deal on some Energy speakers, so these are just sitting around.
Specs -
7" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap. The cosmetic stamped steel frame provides a very high-class and professional look to your next speaker design. The aluminum cone offers a flat frequency response in the passband region with very low distortion. Specifications: *Power handling: 50 watts RMS/75 watts max *VCdia: 1-3/8" *Le: 1.14 mH *Impedance: 8 ohms *Re: 5.9 ohms *Frequency range: 35-10,000 Hz *Fs: 39 Hz *SPL: 85 dB 1W/1m *Vas: .58 cu. ft. *Qms: 3.31 *Qes: .70 *Qts: 0.58 *Xmax 4.25 mm *Dimensions: Overall Diameter: 6-15/16", Cutout Diameter: 5-5/8", Mounting Depth: 3".
$55 shipped
Will trade for NICE components 6.5" (plus cash on my side), a single 10" SQ oriented sub, or a nice pair of 6x9's (cdt preferred)
Specs -
$55 shipped
