Clif Designs CD4800.1LX - 9/10 cosmetics, 10/10 function
700 shipped OBO
True Minimum Impedance Stability: 0.5 Ohms
Power Output Capabilities:
5200 Watts (RMS) x 1 Channel @ 1 Ohm
3575 Watts (RMS) x 1 Channel @ 2 Ohm
1500 Watts (RMS) x 1 Channel @ 4 Ohm
Unregulated Power Supply
Full MOSFET Power Supply and Output Stages
Sigma-Delta Platform
Through Hole Technology
Double Sided Epoxy Military Standard PCB
Center Path Technology (Patent Pending)
Dual 0 Gauge Power Inputs
Dual 0 Gauge Ground Inputs
Frequency Response: 20Hz-330 Hz
S/N Ratio: >90dB
THD:
Input Sensitivity: 300Mv - 8V
Low Pass Variable Crossover: 30Hz-300Hz @ 18 dB per Octave
Variable Bass Boost: 18dB @ 45HZ
Input Impedance: 20k Ohms
Damping Factor: >700
Shipping Weight: 30 lbs
700 shipped OBO
S/N Ratio: >90dB
THD:
