Fs: Cheap batts!!!***
michaellane
Great second batts! had a good amount of PM's here and caco so I picked up some more. I have 14 left as of right now
2. Specs:
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% higher ah rating than a Kinetik HC600
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep up
3. Description/Condition:
only opened for testing
4. Price: :
$45.00 shipped trades or anything need to be sent via PM
Hawker MIL PC AGM Batteries feature the same superior performance as the Armasafe Plus and are sized for a wide range of military vehicles and equipment. *The unique Thin Plate Pure Lead (TPPL) technology of Hawker MIL PC AGM Batteries provides maintenance free operation, longer life, deep cycle capability, vibration resistance, higher starting power, and high reliability.
Hawker MIL PC AGM Batteries have proven performance in the most demanding military applications and continue to deliver best value to today's militaries every day.
Auxiliary Equipment/ATVs
0770-4010
12.6 lbs
MIL PC 545
6140-01-484-5341
7.0 × 3.4 × 5.2
13 Ah at (C20)
$45 shipped
---------- Post added at 10:17 AM ---------- Previous post was at 10:17 AM ----------
The 55ah deka batts will be $90 shipped
let me measure my space under hood when when i get off work. Any idea on the Cranking Amps?
No clue and I wouldnt put these under the hood. I dont know if the case would stand up to the heat. Also not showing any cca id really assume its best to keep as a secondary battery. Those small hawker batts I have listed have 185cca each though
i see. i was just curious. i figured i could run it under the hood then 1 or 2 g31s in the trunk. but yea i just figured id check
The 13ah hawker batts id trust under the hood in my opinion. Taje a look at those and let me know. They are 185cca a piece I think
michaellane
michaellane
tx
big scott
