Sold FS cheap: Ampman Revo 1500.1, eminence 6.5's, Power Acoustik 100x4 amp, other stuff
mysilver02alty
Power Acoustik TS960 - About 15 months old - 75 shipped
RMS Power (4 ohms): 100 watts x 4 chan.
RMS Power (2 ohms): 125 watts x 4 chan.
Bridged RMS Power(4 ohms): 250 watts x 2 chan.
Peak Power Output: 960 watts
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 4 ohms
THD @ Rated RMS Power:
Speaker Level Inputs: Yes
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: Yes
High-Pass Crossover: 40Hz - 250Hz
Low-Pass Crossover: 40Hz - 250Hz
Signal-to-Noise Ratio: >98 dB
Channel Separation: >55 dB
Bass Boost: 0 - 18 dB
http://i139.photobucket.com/albums/q313/mysilver02alty/TS960.jpg
One pair of Eminence Alpha 6c loud speakers, and i do mean loud. Until you hear it, you dont understand. Used for 3 weeks- 55 shipped
Recommended for professional audio midrange applications in a sealed cabinet, or as a mid-bass in a vented satellite enclosure. The Alpha-6C boasts a 4-ohm impedance, increased body weight, and stiffer, more aggressive water proofing treatment on the cone making it ideal for car audio use. Specifications: *Power handling: 100 watts RMS *VCdia: 1.5" *Le: 0.28 mH *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 107-6,000 Hz *Magnet weight: 20 oz. *Fs: 107 Hz *SPL: 93.6 dB 1W/1m *Vas: 0.2 cu. ft. *Qms: 6.12 *Qes: 0.49 *Qts: 0.45 *Dimensions: Overall Diameter: 6.59", Mounting Diameter: 5.69", Mounting Depth: 2.8".
http://www.bltsound.com/index.php?crn=16&rn=482&action=show_detail
6x9 to 6.5 converters - used for about a week- 20 shipped
If yo have 6x9 holes in your rear deck, these make it so you can snugly fit a 6.5.
US Amps ax4300 - one channel not working 130.00 or best offer, keep in mind that ebay is already bid up to 45 plus 30 shipping before offering 50 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The amp has 3 working channels out of 4. I do not know how to fix amplifiers but maybe this is an easy fix for one of you guys. Other than that, its a brand new amp and the other 3 channels are working fine.
One other issue with it is that one of the mounting holes broke off. Im sure its an easy fix for one of you guys. Probably just superglue will fix this. It is easy to see in the pics .
Its basically brand new with like 2 or maybe 3 hours of play time on it at most. Not a scratch on it, its on ebay right now with a big, but if i get a good offer, i can end auction early. Act soon.
75W × 4 @ 4 Ohms
90W × 4 @ 2 Ohms
180W × 2 @ 4 Ohms Bridged
With full xover, RBG, F/R inputs
http://i139.photobucket.com/albums/q313/mysilver02alty/100_0215.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/100_0216.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/100_0218.jpg
Adire Audio - Ampman Revolution 1500.1 - SOLD
heh i was the highest bidder on teh US Amp...lol thats 2 of your amps i bought..lol
Yea, you are the man. Keep it coming. I have a Power acoustik amp for sale too. Btw, they will both be shipped tomorrow. I'll send you tracking info
i got the Adire amp today and its in better condition then you described! good seller here..but the US amps didnt come yet //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Good to hear, i shipped them @ same time, should be tomorrow. I'll pm you the tracking #
Do Not Buy From!!! Sold Me A Bad Amp Then Blames Me
Didnt you just say this last week???
"i got the Adire amp today and its in better condition then you described! good seller here."
Is it working or not???? Make up your mind.
Ive been talking to an amp repairman for a couple of hours now. He said that whoever soldered it could have left a little solder on the pins and shorted it. Or dripped solder somewhere and a bead of solder could have dropped and done worse. Since the amp worked fine for me, it is highly possible that this is what happened. It would make sense that it works for a little while and cuts out now.
This guy who said this to me is a highly respected member on this forum. He fixes amps & other equipment for many members all the time. If you take good pictures of the inside of the amp i can get them to him and he can tell me if its an easy fix or not. He will be able to fix it if you like or tell what is wrong if its an easy fix.
I hope you realize that people are going out of there way for you even though it is not deserved because of your attitude towards me. Im continuing to help you even though you are being a complet a$$hole to me. Im only continuing to waste my time on this because i value my reputation on this site and i have honor. If you continue to badmouth me, you're on your own.
This thread is what this is all about............http://www.caraudio.com/forum/showthread.php?p=2827793#post2827793
mysilver02alty
mysilver02alty
Florida
mysilver02alty
