FS: CDT HD-M6+ Midbass Speakers
bradl79
Pair of CDT HD-M6+
Massive Mid Bass
100% working
Cosmetics 8/10 - Screws holes are not pretty but no issues and one of the speakers has deadener on the back side of mounting ring
Specifications
Diameter: 6.5” (165mm)
Sensitivity: 83.8 dB
Power Handling: 120 WRMS (240W Pk)
Frequency Response: 10 ~ 4000 Hz
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 1.5” (38mm)
Peak Xmax: 12mm
Magnet Weight: 30 Oz
Thiele-Small Parameters:
Free Air Resonance: 39 Hz
Voice Coil DC Resistance: 3.1 Ohms
Voice Coil Inductance @ 1 kHz: 0.71 mH
Mechanical Q (Qms): 2.57
Electrical Q (Qes): 0.451
Total Q (Qts): 0.386
Compliance Volume (Vas): 12.76 l; 0.450 ft3
Moving mass, Diaphragm: 23.8 Gr
Motor Force Factor: 6.35 Tm
155.00 Shipped
On Me
how would you compare these to the hd-6 mids? Im sure these are the winner of the two as far as midbass but how do they do as far as midrange?
I have an answer for this, and I asked Brad if he minds if I butt in. HD-6 will sound great up to the 5-7 kHz range, even though they would never be crossed that high in normal use. HD-M6+ is a small subwoofer that can also play midbass. If I were to use them in my own vehicle I'd cross them no higher than 250 Hz.
bradl79
bradl79
NLR
bradl79
