Sold FS: CDT Audio HD-62 CF ACTV component set
Mattd0344
1. Product:
Here is a link to a similar set..however, my set has carbon fiber mid-woofers. Also, if these ever need to be warrantied (5-year warranty), I'll play the middle man and make sure you get taken care of.
http://www.vertexaudio.com/store/pc/CDT-Audio-HD-62-ACTV-6-5-Active-Component-Set-65p213.htm
2. Specs:
HD-6 6.5” cast mid woofer
HD-2500X installer tuning xover
HD-100 1” silk tweeter
Power handling: 180Watt (high pass 100Hz)
Frequency response:60Hz-20.000Hz
Sensitivity 92.6dB
Impedance 4 Ohm
Surface and flush twtr housings
5 year warranty
3. Description/Condition:
This was an extra set that I had laying around. They were only mounted and tested to see if they worked. They work perfectly and look brand new. The set includes everything that it does when bought brand new and even has the original packaging.
The essence of this system is the HD-Series award winning HD-6 cast 6.5" mid-woofer coupled with CDT's new HD-100 1" silk dome tweeter and the HD-2500X, a special audiophile-designed installer's crossover that can assist in the active tuning process. This crossover is designed to guide and help the installer's ear find the perfect mid-tweeter blend when tuning your system active. The HD-2500X special tuning crossover gives you/the installer the option to use it as an "ear" tuning help tool or, should you decide not to go active after the tuning exercise, the HD-2500X crossover will be your most perfect tuned 2-way crossover for these drivers.
4. Price:
$200 shipped
5. Trades:
Trades are welcomed. I'm mainly interested in an Ipod Touch, 100+ rms 4-channel amp, and a nice double din. Offer anything up, worse I can say is no.
6. Pictures:
Don't mind the CACo_Org....my printer ran out of ink, sorry.
All packaged up....
Yep, mainly looking for an ipod touch, a 100+ rms 4-channel amp, and a nice double din. Offer anything up, worse I can say is no.
***This set sounds better than my Alpine SPX-17REF component set btw. It has stronger mid-bass and a smoother tweeter. I have my Type X components all crazy sealed up to prevent air leaks and dont want to go through the hassle switching them out..
Mattd0344
Mattd0344
Colorado
Mattd0344
