FS: Cadence ZRS C9 600w
bradl79
Cadence Acoustics ZRS C9 600 Watt Peak 16V 4-Channel Class AB Amplifier
100% Working
Minor Cosmetics
Issue with 4 ch negative (screw is stripped, but u can still screw in at an angle and will still hold wire)
Specifications
4 Ohm RMS Power: 100 Watts x 4
2 Ohm RMS Power: 150 Watts x 4
4 Ohm Bridged RMS Power: 300 Watts x 2
PEAK Power: 1200 Watts
Minimum THD:
Frequency Response: 10Hz - 40 kHz
S/N Ratio: > 100dB
Damping Factor: > 640 @ 100Hz
Channel Separation: >65dB
Input Voltage: 200mV - 9V
Fuse Rating: 80 amps x 1 (External)
Dimensions (L x W x H): 15" x 11.6" x 2.7"
Features
• High Speed MosFET Power Supply
• Bipolar Japanese Sanken Outputs
• 16V Capable Power Supply
• Copper Rail PCB Architecture
• 12-24dB Crossover Circuitry
• Preamp RCA Output
• Soft Start Mute and Delay
• Power & Diagnostic LED Indicators
125.00 Shipped
On Me
this thing is identical to the aq90 same build house etc. its a steal at this price //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thank you, it is a great amp
bradl79
bradl79
NLR
bradl79
