FS: Cadence, Hifonics, Eclipse, Monitor 1, Coustic
eg9
1. Cadence A7hc (x2)
2. Hifonics Mars
3. Eclipse ea3422 (x2)
4. Coustic 160
5. Monitor 1 mk2.70
1. Both are great condition, function 100%, clear plexiglass bottoms, one is missing the remote terminal set screw
2. Cosmetically 8/10, function 100%, comes with POS card
3. Both great condition, function 100%
4. Great condition for it's age, functions 100%
5. Excellent condition, only marks on mounting points, comes with original box
SPECS:
A7HC:
500x1@4ohms
800x1@2ohms
1400x1@1ohm
Eclipse ea3422:
Specifications
13.8V Power Supply
Max Power Output 123W x 4 ch (2 ohms)
Power Output (RMS Continuous Power) 2 ohms 70W x 4 ch
4 ohms 50W x 4 ch
4 ohms bridged 140W x 2 ch
THD (Rated Power) @ 2 ohm stereo 0.008%
@ 4 ohm stereo 0.004%
@ 4 ohm bridged 0.008%
Signal to Noise (A-weighted 4 ohm) 105dB
Freq. Response @ 4ohm stereo 20Hz-20kHz +0,-0.7
Crosstalk 4ohm -70dB
Slew Rate 10V/us
Damping Factor @ 60Hz > 200
Input Sensitivity (preout) 0.2-5V
Input Sensitivity (Amp-out) 0.4-10V
Max Current Consumption (4ohm) 50A
Channelflex Crossover
High-Pass Freq Range - 12dB/octive 50~200Hz
Low-Pass Freq Range - 12dB/octive 90Hz (fixed)
Bass Boost (@45Hz) 0~9dB
Subsonic Freq. Range - 12dB/octive 20Hz
Dimensions (W x H x D) 10.82" x 1.97" x 10.82"
Hifonics Mars:
Class A/B
Specs in link below.......
http://www.audiodesign.de/downloads/manuals/GENX_MANUAL.pdf
Coustic 160:
30x2 @ 4 ohms (rms)
2 ohm stable
Clean old school power, great for tweets!
1. $200 shipped each
2. $340 shipped
3. $85 shipped each
4. $50 shipped
5. $90 shipped
On me, tracking info provided when shipped
More pics in post below......
Those Cadence Amps are under rated by a good 2-300 wrms at 1 ohm. The Eclipse are also under rated.
Thanks man! They all are underrated but more so for the Hifonics and Cadence amps. The Eclipse is as well. Definitely more than 50x4 and still very clean power!
eg9
eg9
Winston-Salem, NC
eg9
